03 4runner V8 whining noise
Old Dec 16, 2003 | 05:11 AM
CLin9383's Avatar
not sure if you guys are talkin about the same whine thats in the 3rd gens...but i believe it's the same whine..when i take it up to 80 i can hear it also..only during acceleration...i've always noticed it since i've had my truck in 96..nothing has gone wrong so i just let it be...i think there is a thread about it..but i could not find it..good luck
Old Dec 16, 2003 | 05:15 PM
4Runner_Jason's Avatar
Originally posted by Lefty
Woah, there... Aren't you going a little overboard on this issue ?? In order to have any merit to file a lawsuit you need substantiation that this is indeed a problem that Toyota knows about and won't fix. You're gonna need more proof than an Internet article...
Just some suggestions: Have you checked your tranny, diff, and t-case fluid levels ? As Kaneman suggests, have you greased your driveline ? Better make sure that these are all full/greased. Next, what tires do you have on your Runner ? Have you rotated them recently ? How about tire pressure ? You have the proper air pressure in them ?
Good luck. Let us know how you do with correcting your issue.
Steve
Johnstons Toyota in Middletown NY--crooks, had a Field service tech and dsm, test drive my 4runner yesterday. At 80mph, they heard the noise, and determined its comming from the front differential.
However, they tested another V8, and heard a lesser but similar noise at that speed, and decided that it must be the way the part is designed.
Thus, they refuse to fix anything unless more people complain, and only then will Toyota engineers research it.
Old Feb 27, 2014 | 10:12 AM
jeffpoppen's Avatar
I have a 2003 Toyota 4Runner Sport V8 and I experienced whinin at park, idle, reverse, neutral, and drive...it ended up being the alternator.
Old Oct 19, 2014 | 08:48 AM
mj37kennedy's Avatar
No radio or signals and all dummy lights r on
After changing back hatch battery is not charging all dummy lights r on no radio no signals nothing on dash works help
zombie_barbarossa
Oct 2, 2015 10:54 PM
anniesball
Sep 7, 2015 11:20 AM
norcal98
Aug 10, 2015 06:20 AM
genuinegemini
Aug 3, 2015 04:56 PM
mlavery85
Jul 12, 2015 10:33 AM
