02 Tacoma Front End Damage-How to fix
Old 06-03-2018, 05:19 PM
IronSights73's Avatar
Hey guys, new here. I have a couple of questions on how to best go about fixing some front end damage on my Daughters truck. Her now ex-boyfriend rear ended a Beamer doing about 35 3 weeks ago. We have ordered most of the parts, just a few more to get. The rad support is toast, its tack welded in. What is the best way to get it out? Also the left side core support is rippled. Any ideas as to how to pull it? Thanks for any advice.
-Robert
Old 06-03-2018, 06:37 PM
fierohink's Avatar
I use a self tightening clamp puller and a come-a-long hooked to a tree. Something like this:
Biltek 5 Ton Clamp Self-Tightening Frame Body Repair Small Mouth Pull Clamp 10,000lbs https://www.amazon.com/dp/B00K325XR0/ref=cm_sw_r_cp_api_i_gwkfBbTKS75YA
You pull a little and Hammer the ridges back in, then pull a little and hammer, and pull and hammer until you are past where you want to be, because when you let off tension it will relax back some.
Old 06-04-2018, 12:11 AM
wyoming9's Avatar
Red face
I think they use spot welds on the radiator support .
Having had to cut out many spot welds I have found the Snap On Spot weld cutters to be the best.
Yes they are expensive they cut the outside of the spot welds .
That was quite a few years ago might very well be better cheaper options
Another option is many drill bits just slightly larger then the spot welds
Old 06-04-2018, 04:54 AM
Malcolm99's Avatar
To remove the rad support you can drill out the spot welds, then tack the replacement back in place, very common method of repair.
Old 06-05-2018, 06:24 AM
thanks all!
Old 06-05-2018, 06:45 AM
Robert m's Avatar
I have heard very good things about rotabroach spot weld cutters but never used them personally.
KevinRandall
04-25-2018 04:58 AM
4rollin
12-05-2015 07:17 PM
cfhrduncan
13
02-28-2013 08:44 AM
3000GTVR4
09-18-2009 03:51 PM
91TPU
03-10-2009 11:07 AM
Quick Reply: 02 Tacoma Front End Damage-How to fix
