02 sensor code after sensor was replaced
Old Mar 11, 2008 | 12:17 PM
tiredandwired's Avatar
Hi-
I just bought a 95.5 Tacoma 2.7l w/ 122,000 mi. I had the head gasket blow after 2 weeks and had it replaced. It also fried the front 02 sensor. A couple of weeks after the HG repair, I had the sensor replaced. The mechanic found that the previous owner had the other sensor welded to the pipe so I had both the pipe and sensor replaced with OEM parts.
A couple of days later, the CEL comes on again with these codes:
P0130
P0133
My mechanic checked the sensor itself and it is functioning within range. Before he starts the full diagnostic procedure, ( I'm running out of money), is there anything anybody can think of to check?
Thanks
Old Mar 11, 2008 | 12:49 PM
edzo's Avatar
as for the o2 sensor voltage, verify you are looking for toyota's numbers
for your year and engine year and run the engine test pattern. the voltages
are pretty tight between sensors that work and sensors that are not the correct one
then in this order, check these things
check wiring harness between ecu and sensor
check air induction system
check fuel pressure
check injector injection
replace 02 sensor again
if all the above checks out, replace ecu
Old Mar 11, 2008 | 04:01 PM
Thanks! Do you know what my year and engine year voltage ( range?) is for the sensor or can you tell me where I can find that info. for my mechanic? I'm trying to do some of the research for him.
Old Mar 11, 2008 | 06:41 PM
edzo's Avatar
no I don't have that info, sorry
someone here might have it. you may check the part
number and see if it is shared with other toyota's.
it is likely the same sensor used in a number of vehicles.
dealer will be able to look it up
I know 2000's should be:
warm up engine
run at 2500 rpm for 90 seconds
then idle. measure voltage. it should alternate between
less than 0.35 volts and more than 0.55 volts. good
if it alternates, and the lower voltage is higher than .35, no good
if it alternates, and the high voltage is lower than .55 it is no good
it needs to make a voltage swing past the .35 low and .55 high
now this is on a 2000 with no air injection and no egr, your sensor specification
may be different
TURBOrunnerNM
Jul 22, 2015 11:01 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
coryc85
Jul 6, 2015 04:07 AM
