01 taco 2.4 auto. Amsoil conv and fuel filter question
Old Dec 28, 2007 | 05:47 AM
Baloo's Avatar
My Taco has about 150K. Well maintained. Oil changes every 3K. No leaks.
I have a couple questions. I searched and am sure the answers are there somewhere but ....
I want to change to synthetic. Once, a long, long time ago when I did it to a higher mileage car (70K +) it developed leaks all over the place. At the time I was told there was a window for converting that I had passed.
Has anyone else done this on a higher mileage vehicle without problems?
What filter should I use? I would like to get a bigger one.
An last, on the fuel filter. You know, the "lifetime" one. Do I need the snap tools to remove it?
This is among my quest for better gas mileage, a lot of information which I obtained through you guys.
I have a full weekend of maintenance planned since I have to do the half shaft on the drivers side as well and am considering flushing the trans and converting it to Amsoil as well.
Old Dec 28, 2007 | 04:43 PM
Midget96's Avatar
I started using Amsoil XL when I first got my truck. It had 149K on it and who knows what the guy before me used in it.
I have 184K now, and have zero oil leaks. I go 8000-10000 miles between oil changes, too.
You can replace the fuel filter with a wrench and a socket. Nothing special.
Old Dec 28, 2007 | 04:49 PM
fillsrunner4's Avatar
Flush the trans but dont change to synthetic. Its not a wise choice for the fact that you most likely will start to leak. Its thinner and if anything you should use a bit thicker. Stay with the High mileage. As for the fuel filter no special tools are needed but disconect the fuel pump wires and start the truck till shuts off so you dont get covered in gas. As for air filters, do you have a stock airbox??? if so if you want an intake for a bit and i mean a bit better mileage i would go with a AEM intake kit. best and easiest filter to clean and it will outlast you truck
Old Dec 29, 2007 | 12:22 AM
ARB1977's Avatar
I would keep doing what your doing...change that fuel filter and enjoy another 150K.
Old Dec 29, 2007 | 09:52 AM
Baloo's Avatar
I just realized that the subject list the wrong size, it is a 3.4L.
The fuel filter is a given. Still somewhat concerned about switching to Synthetic with this many miles, but will probably risk it using a NAPA Gold filter.
For the trans I will probably just change the filter and stay with the regular atf since the only comment I got was to the negative.
Thanks for the help guys..
Old Dec 30, 2007 | 01:15 AM
ARB1977's Avatar
The auto trans doesnt have a filter it has a screen. I added a remote filter kit between the stock cooler and trd cooler...makes filter changes a piece of cake.
Old Dec 30, 2007 | 11:03 AM
Midget96's Avatar
I'd use a Purolator PureOne filter. One of the best on the market and has enough filter media to last for long intervals.
Again, you'll have no issues with the transmission, either. I flushed mine with Amsoil ATF last summer, and 17K miles later, no leaks of any kind.
Only thing that happend when switching to a high quality synthetic ATF was smoother shifts and piece of mind...
I don't know why people are so apprehensive about going with synthetic on high mileage vehicles. It's not at issue.
Old Jan 7, 2008 | 06:13 AM
Baloo's Avatar
The 01 3.4 does have a filter. I have it sitting here but am still on the fence post about the sythetic ATF and how to properly flush, so will hold off on that.
Did the Oil filter, oil change (Mobil 1 this time, Amsoil next) and put in a new TPS (was throwing an intermittent P0120) code) this weekend as well as a seafoam treatment. Obviously not long enough to notice any change yet, but keeping my fingers crossed.
Old Jan 7, 2008 | 10:50 AM
hopper's Avatar
I had over 175,000 miles on my 4runner before I switched to Mobil 1 synthetic. No problems what so ever.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
Fundy Rider
Jul 16, 2015 01:35 AM
