01 gauge cluster in 2000
Old May 26, 2008 | 01:48 PM
bradnuts's Avatar
hi.. new to the forums.. did a search and couldn't find an answer... i just put a gauge cluster from a 01 4runner into my 2000.. i had to change the circuit board on the back, so the plugs would match up... well.. everything seems to work, except
my temp gauge is always on hot,
the abs light stays on,
the parking brak elight stays on whether or not the brake is set,
and finally, when i turn on my hi beams, both signal indicators light up instead of the hi beam indicator
any ideas? or do i just need to find a cluster from a 2000?
thanks in advance
Old May 26, 2008 | 02:25 PM
DeathCougar's Avatar
yank that thing back out of there and find one from a 2000. The 01 is completely different, as you have found out
Old May 26, 2008 | 02:44 PM
scuba's Avatar
lol
Old May 26, 2008 | 03:18 PM
bradnuts's Avatar
haha.. thanks... i knew it was different.. but it came as extra parts with the truck.. and i needed a cluster to use... so i figured it would be temporary for now.. just wanted to see if there was anything i could do to make it work while i was looking for a cluster from a 2000.
thanks for the help!
Old May 27, 2008 | 07:41 AM
blarchitect's Avatar
If you can get hold of the wiring diagrams for both models you may be able to make it work. Anything is possible but you'll fritter away the hours finding out!
Matt89toyota
Jun 27, 2023 08:00 AM
jacked_72
Sep 14, 2015 03:31 PM
imhousing
Sep 10, 2015 02:04 PM
Rawwdz
Sep 6, 2015 09:03 PM
