01 4Runner low brake pedal???
Old Aug 14, 2012 | 02:05 PM
Sublime69's Avatar
My 01 4runner has a low brake pedal. When im coming to a stop i can give them a quick pump and they feel fine then. The pads are ok and i just bled the brakes. Still have a low pedal. Master cylinder?? Rear drums need adjusting??
Thanks!
Old Aug 15, 2012 | 01:06 PM
Sublime69's Avatar
Anyone??
Old Aug 15, 2012 | 02:45 PM
rokblok's Avatar
If its a good firm pedal once you give it the quick pump, I would check the rears(if drums) and make sure the lining is ok on the shoes, clean them of, and adjust them. My truck has done this, a few clicks on the adjuster and its all good.
Good luck!
Old Aug 15, 2012 | 07:00 PM
JBurt's Avatar
I also had this problem. I replaced my brake lines with stainless steel ones and that helped a lot too. I guess the old ones swell up after so long i guess. I'd. Start with the shoes though
voiddweller
19
May 2, 2016 09:10 PM
toyota32
Jul 6, 2015 05:42 PM
CJ94yota
Jul 3, 2015 10:14 PM
gog1968
Jun 22, 2015 05:55 AM
