wally's 874runners continuation thread from t4r.org
Old Nov 7, 2022 | 05:09 AM
wallytoo's Avatar
since there was still some daylight after i walked the property boundary lines (and flagged them), decided to go for a quick ride before dark.
i'd be seeing signs like this a lot the next day
north edge of the camp property to the right
back at camp for an evening beverage and place to watch the sunset
heating up some dinner and wash water
soup's on!
using one of the cots for food prep/gear stowage
Old Nov 7, 2022 | 05:21 AM
wallytoo's Avatar
up before sunrise to begin a day of wheeling!
nice sunrise, ready to go
don't see a lot of pipelines in new england
a lot of arrow-straight gravel roads up here
this is the kind of road i've been wanting to explore
sandy two-track
chatted with a bow-hunter who had family nearby, but he hadn't seen any deer yet that morning
not many hills, either
open country
Old Nov 7, 2022 | 06:37 AM
coryc85's Avatar
Great pics Wally. What is that tower above the camp shack?
Old Nov 7, 2022 | 07:24 AM
wallytoo's Avatar
zip line platform!!!
not. it was briefly topped with a wind turbine, but the bearings failed in it less than 2 years into it's use back in the mid-80s. father-in-law built it all, but decided not to dismantle the tower after the turbine failed. next year i might just climb it to see the sunrise or sunset.
Old Nov 7, 2022 | 07:29 AM
  #25
wallytoo's Avatar
winding through the woods, or straight. lots of young softwood plantations. not technically challenging, and mostly 2wd exploring
Old Nov 7, 2022 | 07:34 AM
  #26
wallytoo's Avatar
needed to keep moving along most of these "beach sand" areas, otherwise i'd sink in a bit with very little to anchor to
lots of DNR roads, too. about 50/50 as far as running DNR or county roads
snack stop location
even with the darker soil mixed in, this is nearly beach sand consistency
aired down to 8 psi front/rear
Old Nov 7, 2022 | 07:41 AM
  #27
wallytoo's Avatar
slight washboard visible in this loose surface
lot of great upland bird habitat here
a bit more packed gravel
back to the sand
when i slowed down enough, i could feel the back end start to dig/wallow in the sand, so i just kept the speed to around 8 or 10 mph
Old Nov 7, 2022 | 07:51 AM
  #28
wallytoo's Avatar
more long sandy straight roads
something different! some puddles!
a little bit of fall color still there
more great bird cover
Old Nov 7, 2022 | 07:54 AM
  #29
wallytoo's Avatar
fairly large shrub wetland system
Old Nov 7, 2022 | 08:02 AM
  #30
wallytoo's Avatar
long straights, and more water
actually met a pickup coming towards me along here
loosest beach sand of the trip
one clump of trees in the midst of a big patch cut
about 250 acres of recent patch cut
Old Nov 7, 2022 | 08:11 AM
  #31
wallytoo's Avatar
zooming along on a long straight
another of the "infinity" roads - nothing like this in new england, not even northern maine
aspen
last of the sand
almost back to camp
more aspen
Old Nov 7, 2022 | 08:23 AM
  #32
SomedayJ's Avatar
Nice!
Old Nov 7, 2022 | 08:39 AM
  #33
wallytoo's Avatar
switching back to the road set, enjoying a beverage in the warm late october afternoon
ready for the pavement again
second night dinner prep underway
time for supper
a pleasant evening
ready for bed
Old Nov 7, 2022 | 08:47 AM
  #34
wallytoo's Avatar
woke up at 3 am in the camp, couldn't fall asleep again, so i got up at 4 am, started a fire, heated up my coffee and pop-tarts, then packed up and headed out. still dark at 5 am when i headed out. since i was getting such an early start, i decided to head north to set foot in the UP of michigan.
close to the UP, and happy halloween
crossing the Mackinac Bridge to the UP
first time in the UP. sunrise over lake huron and lake michigan.
time to start the 4 hour ride back to southern michigan
Old Nov 7, 2022 | 08:55 AM
  #35
wallytoo's Avatar
lake huron to the east...
and lake michigan to the west
crossing the Mackinac in daylight
the end
all told, put 2294 miles on the 4runner, used 123.14 gallons of gas, which averaged out to 18.6 mpg, and spent $478.64 on the gas. pretty happy with that, as the 4runner was freighted with the extra set of off-road tires/wheels, and the mpg includes nearly 200 miles of wheeling. for comparison, with the white '87 in august, doing the same route except for going to the Mackinac and no wheeling, i averaged 24 mpg.
Old Dec 10, 2022 | 02:10 PM
  #36
wallytoo's Avatar
did some towing last month...
Old Apr 6, 2023 | 05:07 AM
  #37
wallytoo's Avatar
did some towing with #1 yesterday - needed to move pallets to the sugar house to stack cordwood for drying.
Old Apr 6, 2023 | 05:20 AM
  #38
wallytoo's Avatar
and some pics from this winter that i fogot i took...
parked for work...
sunrise after a light ice storm..
Old Jun 3, 2023 | 12:50 PM
  #39
wallytoo's Avatar
after mulitple decades in new england winters, the license plate light assembly was pretty rotted, and one of the lights wasn't working (no surprise, since most of the metal housing for the bulb was rusted away - literally missing most of the housing). i am not a metal worker, but i can do fiberglass, and the plate light housings are not visible when mounted in the tailgate housing. i also used gorilla glue to repair the ABS tabs which the light housings mount to. but first, i needed to remove the assembly from the tailgate. this means the inner tailgate panels need to be removed, and the window then needs to be in the "up" position. i unplugged the wiring connector that is mounted behind the glass on the inner side of the tailgate skin, and removed the two 10mm nuts that secure the light housing/key operator to the tailgate. there is a third mounting point, at the mid-point along the housing, that needs to be released. this is done via a small set of pliers and gently squeezing the plastic tabs inward while lightly pushing down. the entire housing should now pop free.
i fished the end of the housing wiring harness out from the tailgate, and took the unit into my workshop. i completely disassembled the housing in order to repair cracked/broken ABS, to paint the metal mounting pins, etc. in order to do this, the keyswitch needs to be removed. there is a pin on the inner side of the tumbler to release, and the unit will separate into two pieces.
the "back" half of the tumbler, with the keyswitch portion already removed, showing the release pin access
keyswitch fits into this
keyswitch, showing release pin
release pin, and the part that operates the actual switch in that other half.
Old Jun 3, 2023 | 12:57 PM
  #40
wallytoo's Avatar
once the unit was stripped, i cleaned it and then repaired the broken tabs using gorilla glue (actually, i had 3 housings, and repaired all three).
repaired ABS tabs
repaired light housing, fiberglass shell using what remained of the original metal housing. about 1/2 of the metal was gone (all the parts have been sprayed with fluid film, which is the coating visible here - even coated the fiberglass. note the center mount lug (to the right) - the one that needs to be lightly squeezed to release it from the tailgate
although not visible, i used stainless screws to mount the light assembly to the tailgate trim housing.
