thebeeler 1994 Pickup Build-Up Thread
Old Nov 7, 2014 | 11:10 AM
  #61
thebeeler's Avatar
Old Nov 8, 2014 | 11:01 AM
  #62
bump530's Avatar
I guess I missed where you decided to go the LS route. Should be a fun build.
Old Nov 8, 2014 | 05:03 PM
  #63
JasonYota's Avatar
What happen to staying with a manual trans?
Old Nov 14, 2014 | 04:58 PM
  #64
thebeeler's Avatar
Old Nov 16, 2014 | 10:28 AM
  #65
FK.'s Avatar
FK.
That front bumper changed the look of the truck so much, love it! Looking forward to seeing what you do with that LS in there
Old Apr 27, 2015 | 11:59 AM
  #66
thebeeler's Avatar
Well I guess I should update this. Ended up getting a full size Chevy to stick the LS1 and all the other parts I have been accumulating. I was getting tired of seeing my perfectly good truck in pieces, so I put it back together. Called up ENGNBLDR with the expectations of building a ˟˟˟˟ty engine with ˟˟˟˟ty parts. Ordered oversized stainless valves, springs, .270 Cam, full rebuild kit, and some other parts. When the parts came in I was surprised by the quality of the parts. I would recommend them to anyone looking to rebuild a 22RE on a budget. Engine has around 1k miles on it to date and has been preforming flawlessly, getting around 17mpg mixed city/highway
The Chevy that I am building, center mount front end, 4 link rear, full 2" 4130
Putting the short block together.
Cleaning up some parts, most if not all parts got glass beaded.
Assembled ready to drop in
Old Apr 27, 2015 | 12:03 PM
  #67
thebeeler's Avatar
Ran into some issues while putting it together. Broke a couple studs/bolts so a call to 22RE performace was in order. I got all new hardware.
Ran into some Fuel line issues as well, had custom -4AN lines made at One Stop Shop so all the OEM rubber lines are eliminated.
Old Apr 27, 2015 | 12:08 PM
  #68
thebeeler's Avatar
While the engine was out went ahead and got some solid engine mounts from 4x Innovations.
New Ac pump as well
How much I had to cut off my grille to make it stop rubbing on the Addicted Offroad plate bumper.
Old Apr 27, 2015 | 12:10 PM
  #69
thebeeler's Avatar
Also got my BudBuilt skids all painted and put on.
Under carriage has a nicer paint job than the rest of my truck now
Did the corner marker light, turn signal mod with some XB LED strips in amber from The Retrofit Source. They are rear firing and illuminate the marker light very well.
Old Jul 21, 2015 | 10:06 AM
  #70
thebeeler's Avatar
Truck has been running great, engine hasn't had any problems yet. Went on another night at Ocotillo Wells run with a group of Toyotas from Tacomaworld. Alternator died when I got back home, couldn't handle the mud/water I guess.
Siting up towards the top of Blow Sand.
About 30minutes later at Devils Slide
Top of Shell Reef
The group at Shell Reef
Gasin up at the Arco by Salton Sea, tons of random people snapped pictures of my truck because of how dirty it was.
Old Aug 18, 2015 | 03:28 PM
  #71
thebeeler's Avatar
At 3.5years old my BFG KO's were starting to show their age, they were a little louder and a little rougher than they used to be. But that is to be expected from a tire as they wear out. I have no complaints about them at all. This is the second set I have personally worn out. So an order for a new set of Ko2's in 31x10.50R15 was made.
Old Aug 18, 2015 | 03:35 PM
  #72
thebeeler's Avatar
Had noticed the smell of anti-freeze when the thermostat was opening up, started looking around, noticed my radiator was starting to leak at the tank seams. Order an new one from the local radiator shop, shop ordered me an all aluminum radiator. Quality of it is pretty good, was the same price as a normal one with plastic tanks. So if it lasts longer than 3years, average life of a radiator in my trucks, i'll end up ahead.
Also hit 220k the other day
Was having some problems with my Vision X Tantrum light kit, it's not a very good kit. But anyways they sent me out 8 new lights that won't work with my existing kit so that was pretty cool of them.
Old Dec 28, 2015 | 10:27 AM
  #73
thebeeler's Avatar
Picked up up some Deavers, doing a SUA swap soon
Also got my seat redone.
Old Dec 28, 2015 | 06:28 PM
  #74
yota81's Avatar
awesome. keep it coming.
Old Mar 10, 2016 | 07:39 PM
  #75
thebeeler's Avatar
Some more parts put on
Old Mar 10, 2016 | 09:19 PM
  #76
Jestsurf's Avatar
Subbed, keep it comin!
Old Mar 16, 2016 | 11:37 AM
  #77
thebeeler's Avatar
Was going to change out all the bushings for urethane's since my UCA bushings had fallen apart after 235k miles, not bad for stock parts. Went to remove the LCA, and 3 out cam tab bolts would not come out. An air hammer managed to break one more free, leaving me with two stuck bolts that would not come out. The result of this was having to cut the arms and bolts off. Then install Total chaos, the difference in price to put it back to stock vs "Long Travel" was worth it to me. It offers added security when wheeling in remote locations alone, which is how most of my wheeling is done.
Start of tear down
Cut bolt
More little ˟˟˟˟ that turns a simple job into a night mare
The allen are nice, cause they sit flush. But they strip easy and fill with debris
Old Mar 16, 2016 | 11:44 AM
  #78
thebeeler's Avatar
Kit was very easy to put on, everything bolted right into place. It requires the building of a shock tower and hoop. You also have to remove your old torsion bars and the stock shock mounts.
Upper arm
Shock Tower
Frame Plates welded on with my squirt gun
All mounted and cycling to limit the travel for 4x4
She's a little wider meow
Out breaking it in, works great as expected
Old Mar 16, 2016 | 12:34 PM
  #79
jhuggz2502's Avatar
nice work! is this a 4x4?
Old Mar 17, 2016 | 09:56 AM
  #80
sphealy's Avatar
Yeah its 4x4 you can see the half shafts in the picture above.
