Thatguy1295's 89 Single Cab SAS build
Old Jan 21, 2012 | 05:00 PM
ThatGuy1295's Avatar
So heres my pretty little 89
3VZ, 5 Speed, 4.88's, 33's, rear spool, no lift, cut fenders.
Performance= impressive
Then I bought an 01 taco.
And nobody needs two pretty trucks, right?
So I SAS it. Hired a friend to remove the stock IFS, do the leaf spring hangers, build custom spring packs and setup the high steer. He's been doing them for years and did an amazing job.
Wishin id took more pictures of this part but I didn't.
Rebuilt the front and rear axles completely.
Rearend's got Chev 63 springs, 5.29's, Spool, new brakes and wheel bearings.
Frontend Custom spring pack, 6 bolt knuckles, high steer, Longfield 30's, 5.29's, Detriot high pinion diff, and some extra armor.
Then began the exocage. I did not have a shop to work in so this was all done outside. And with no help
Bed goes by by.
Time for some paint
Then I got some 36'' swampers for cheap.
Now lets drive it
The detriot locker, high pinion front diff,
Yup,,, it works. Lets go wheeling
And yea I fixed the front tube to bumber transition.
More wheelin
Wheeling:
And lets not forget about these videos
Rally car for dirt bike track building:
http://s1201.photobucket.com/albums/...underBird2.mp4
Some elbe:
PARTS LIST: Longfeild 30's, 5.29's, spool in rear, detriot up front, six shooter knuckles, highsteer, dual optima yellow top's, chev 63's in rear, pelican 1660 tool box, 2 8K winches F&R, Hella 550 lights, on board air (AC compressor mod, with oiler, and oil separator), long field hub gears,
real waterproof led ground lights for night wheelin theres more
RECOVERY/GEAR IN TRUCK: High lift jack, Shovel, Axe, Saw, 2X25' spools of 3/8 cable, HD snatch block, 5 D rings, block and tackle type come along, home made 3/8's snow chains, Glock 9mm, first aid kit, 154pc craftsman tool kit, and of coarse 2 winches
Old Feb 7, 2012 | 08:31 PM
DirtyOregonKid's Avatar
Looks fun. I was hoping for some info on the dual battery setup.
Old Feb 8, 2012 | 06:15 AM
This trucks got dual's in a parallel configuration. But I run an isolator with 2 batteries on my other truck. All depends on what your using it for the most. Winching, stereo, ect...
Some pretty good arguments in here if your interested
https://www.yotatech.com/forums/f131...rnator-248058/
I went with 2 yellow top optima's mostly because on of the batteries is located behind the passenger seat. Didn't really want a plastic box full of acid in the cab with me. And their awesome batteries, just coin. Mostly did dual's for the winches on this truck, but haven't had to use them very much, which is good but still nice knowing its got plenty of juice.
Old Mar 14, 2012 | 07:36 PM
westjohns yota's Avatar
ive seen you on this form for awhile now and have always wanted to see a build thread on this rig and i love it! ive ot my 82 and wanna runs 36s how much lift did you have to go with? im putting 3in spinrgs under it now but idk if thats enough, really dont wanna do a BL...
Old Mar 14, 2012 | 08:11 PM
__________________
Thanx.
Not sure about the lift since it was a conversion from ifs to solid axle.
I used the rear springs up front. To me it seems like a good 6 maybe even 7 inches taller then it was with stock ifs. Plus I cut 2'' out of the fenders.
If you want I can get you some hard measurements off the frame. Give you an idea. Though I think your frame has more of an arch in the front cause it came with a solid axle. But let me know if you need some info.
Old Mar 14, 2012 | 08:28 PM
BoredOutnJackdUp's Avatar
It depends on how much you wanna clear them by. 3 inch would be plenty.
Your truck is so bitchin Thatguy!
How did those home made tire chains work for ya?
Love the F&R winches.
Old Mar 14, 2012 | 08:45 PM
Thanx.. The chains are a toss up. They seem to work awesome in really icy choppy snow. But in powdery deep snow they actually seem to make it harder. Especially for those behind me. But they were definitely helpful up by mt. rainier on some of the loggin roads were its just rough and nasty. Air down to 10psi with the chains and there aint much stopping it
I think more importantly I just always wanted to build a set, even if there not necessary.
Old Mar 20, 2012 | 07:05 AM
"Thanx.
If you want I can get you some hard measurements off the frame. Give you an idea. Though I think your frame has more of an arch in the front cause it came with a solid axle. But let me know if you need some info. "
yeah you can def some measurements, im trying to clean 36s and i know 3in springs def wont be enough, were did you get your shackles at? a friend of mine has ones in almost the same length and he can clear anything, the places he got his at went out of buissness.
Old Mar 20, 2012 | 07:42 AM
rattlewagon's Avatar
Does your tierod hit the frame at all? How much uptravel do you have?
Old Mar 20, 2012 | 07:50 AM
Tie-rod doesn't hit on the ramp. But theres paint missin on part of it, so I know its rubbing a little if I hit the bumpstops hard enough.
Made the shackles.
Ill set up the ramps and pull some measie's for you guys here in the next couple days
Old Mar 21, 2012 | 05:26 PM
MalachiRunner's Avatar
[QUOTE=ThatG
Just have to say...the 9mm is the best add to a recovery kit I've seen yet.
Old Mar 21, 2012 | 05:49 PM
Ya it can be helpfull
Old Mar 21, 2012 | 07:11 PM
oh crap, i'm sorry dude! i am new on here and am not sure how to do that...i'll figure it out...my bad.
Old Mar 21, 2012 | 07:13 PM
Oh don't worry, I was just wanting less clutter
Thanx for clearing it
Old Mar 27, 2012 | 07:01 PM
moroza's Avatar
Definitely a change from how it was stock!
I notice that in the first pic of the SAS, you have an early, non-gussetted front axle. A later pic shows gussets. Did you add them?
Chains not so good in powder? Learned something new...
Why two winches, instead of one that you can move front to back?
Old Mar 27, 2012 | 07:12 PM
Your the first to notice. I actually switched housings during the sas. I got a newer trussed housing for free, I pretty much had it completely dismantled already so I figured why not. Then I added the upper truss myself.
Permenently fixed winches can be mounted in much better spots in my case. And I like the simplicity of having them ready to go. No plugs, pins, having to move your winch in/under the mud. Winch power plug ins get all nasty and stop working after a while. Mostly just like gavin winches front and rear, plus the rear was a little light so I'm ok with some extra weight.
Plus the front winch is hooked up to controls in the cab for quick use
Old Mar 27, 2012 | 07:41 PM
westjohns yota
Have some ideas, but not sure how to compare the 2 yotas for lift hights.
Only thing I can think of is motor mount to top of axle. Since I know our frame or different. Mine is 15'' from top of axle to the top of the fram portion of the moter mount.
Travel is rediculous, short of posting all the specs. The bottom of a front tire can be 3 1/2 feet off the ground before the rear tire starts to pick up. Lots of flex, and lots of travel. I am currently running a limiting strap in the front so the driveline doesnt pull apart. So I can't actually tell you the max travel of the front axle. But the articulation is unaffected.
Old Mar 28, 2012 | 11:41 AM
racerflea's Avatar
Nice truck what do you have planned for in future?
Old Mar 28, 2012 | 02:37 PM
Dual cases mostly. Does great without it, but would be nice to be able to take a nap while the truck is still drivn.
That and lots of wheeling....
Old Sep 10, 2022 | 02:56 PM
sold it years ago,,,,,,, and really miss it
