Swimmerboy2112's 1986 4Runner Build-Up Thread
Old Nov 16, 2011 | 08:47 PM
  #3241
irab88's Avatar
did you get the farenheight or celcius version? they make both
Old Nov 17, 2011 | 05:04 PM
  #3242
Swimmerboy2112's Avatar
I accidentally ordered the Celsius version, then realized my mistake and had my order corrected to the Fahrenheit version, so I guess it is really gonna be up in the air as to wether I get the Celsius or Fahrenheit. lol
Old Nov 17, 2011 | 07:53 PM
  #3243
ToyoTech559's Avatar
ill be happy to take the arb off your hands hehe
Old Nov 17, 2011 | 08:24 PM
  #3244
xxxtreme22r's Avatar
Or he can give it to me. I'm closer.
Old Nov 17, 2011 | 08:35 PM
  #3245
irab88's Avatar
uuuh... the arb is on his yellow runner... i don't think it's coming off anytime soon
Old Nov 18, 2011 | 03:06 AM
  #3246
Wink
You two are dreamin!
You nailed it Ian!
Old Nov 18, 2011 | 12:15 PM
  #3247
Just got off the phone with LCEngineering, they said the headers from a first gen pickup will fit on my 4Runner... YAY! all i need to do is run a gasket from an 86' (duh) which I already have.
Old Nov 18, 2011 | 04:52 PM
  #3248
Originally Posted by Swimmerboy2112
My only issue with a SAS right now is mounting my ARB back on once the swap is done, I won't be able to use the same mounting points because of the front spring hanger. I would just weld it on but then i won't be able to get my winch out if need be...
Old Nov 18, 2011 | 05:25 PM
  #3249
irab88's Avatar
yeah... but i don't know how soon the sas is going to happen
(jk- but really, sas done yet? )
Old Nov 18, 2011 | 08:42 PM
  #3250
john4wd's Avatar
The ARB mounts under the frame rail like mine, what I would do if I was doing an SAS, the front spring hangers are on the front tip of the frame and the ARB has steel plates going towards the frame and instead of the mounting under which with an SAS you can't do and I would welds on some more plates to be able to mount on the side of the frame Instead of underneath, Just like the other mounting points on both sides on the front 2 body mounts.
I just looked at my bumper and body mounts pics on puter, There really is no reason to be able to reattach the ARB to the 2 bolts where the factory tow hooks go? Or just cut off that area and you will still have the outer ones and the 2 on the front cross member, that is plenty? just get grade 8.8 metric, if you still want more mounting then make a plate and weld it and that will be U shaped to go under the body mount and bolt it to the side of the frame instead of beneath...
Cut this area out...
Drivers side, Weld on a plate here and drill some pass through bolts holes through the frame and bolt that there...
On passenger side, Same thing weld a plate, drill some pass through bolt holes through the frame and bolt that there...
Your going to do some welding or have welding done for front spring hanger and the through bolt hanger through the frame, so you can do or have the bumper modified. Or just cut out the white area on the first pic, and just use the remaining attachment bolts only, Just some idea's I'm throwing at you...
Old Nov 19, 2011 | 04:25 AM
  #3251
In due time my good friend, still shopping around for the best deals...
Awesome! Thank you!! This is something of what i'll be doing, I think it's gonna be one of those, do-it-as-i-go things but awesome pics thanks a lot!
Old Nov 19, 2011 | 05:57 AM
  #3252
RBX's Avatar
RBX
Get yourself some POR-15 and a wire wheel to clean and coat everything you can. The rust belt we live in will wreck your project.
Old Nov 22, 2011 | 12:35 PM
  #3253
Got some ordered!
Old Nov 22, 2011 | 12:48 PM
  #3254
B-yodaful's Avatar
Hey swim where did you order that por 15?
Old Nov 22, 2011 | 12:56 PM
  #3255
Right from the source!
http://www.por15.com/
Old Nov 22, 2011 | 01:13 PM
  #3256
john4wd's Avatar
POR-15 is expensive, was $32 bucks with tax for a pint at Lafayette's only Body only parts store, I was stunned!!!! He says here is another brand of the same formula for around $15 a 1/2 pint and if you add is up your only saving 2 bucks, so I just got the por-15. Next time I'm getting the 6-pack Por-15 in the smaller cans so not waste as much as I did...
Old Nov 23, 2011 | 04:23 AM
  #3257
yota721's Avatar
Thats Expensive!... im glad i live in the south where i dont got to worry about rust too much.
Old Nov 23, 2011 | 11:23 AM
  #3258
Yeah its a lot of money but well worth it in my mind.
Yeah yeah yeah rub it it!
Old Nov 23, 2011 | 12:28 PM
  #3259
MaK92-4RnR's Avatar
So have you decided when/where this SAS is taking place? what kit are you going with and what size? what size tires are you shooting for?
Old Nov 24, 2011 | 02:50 PM
  #3260
Looks like the SAS will be taking place in the spring/summer.
Going to go with the IFS Eliminator Kit 3" up front with the 3rd leaf removed and 3" out back.
Planning on running 35's!
