Project "Striper" Build Thread
Old Nov 27, 2017 | 04:25 PM
  #161
Heironymous Josch's Avatar
Originally Posted by Melrose 4r
Looklng good and making me envious. Cant wait to see how it comes out.
did you consider having the whole assembly balanced? I had the 22re in a Celica GTS
balanced when it was rebuilt and it felt amazing afterward.
Thanks!! You know, if my machine shop bill wasn't already what it was - with boring, light decking, turning all the lobes on the crankshaft and reconditioning the rods - I might have done just that. I paid on the high end for my machine work too but this is the only reputable shop in my city. Gotta love New Orleans.
Old Nov 27, 2017 | 06:23 PM
  #162
Well, I got the engine back from the machine shop (again) today. All is good. I had the compression rings swapped in their lands on the pistons. Pistons are in, only snag I hit was on the 4th rod where, after tightening the cap, the crankshaft was bound. Luckily I'd been checking as I went and knew the problem was on the 4th rod and doubly lucky I put maker's marks on my rods during disassembly. So, it only took a few seconds to diagnose that the rod was rotated on the piston and a few minutes after that to pull the piston, yank the wrist pin, rotate the rod, reassemble and reinstall.
The oil clearance on the rod journals checked out as well:
Up next, oil strainer, main seals, oil pan and sensors on the outside of the block.
Thanks for stopping by!
