prerunning4x4's 1991 Pickup Build-Up Thread
Old Nov 6, 2010 | 10:58 AM
  #121
prerunning4x4's Avatar
About to start pulling things from the motor for either the timing belt or a whole new motor. Whichever holds the issue. Going to order (on monday) Front and rear Diffs with 4.88 gear ratios with F&R Lockright lockers. My Aussie has reeked havoc on my old 3rd.
Old Nov 6, 2010 | 11:20 AM
  #122
irab88's Avatar
oh no! not an aussie! what havoc was reeked?
Old Nov 6, 2010 | 12:22 PM
  #123
The pinion shaft has gone soft, and it likes to skip a lot, and make bad noises at high rpms. Its an easy fix, but its cheaper to buy a whole new diff and fix/sell the old one.
Old Nov 6, 2010 | 12:38 PM
  #124
irab88's Avatar
ok, good. at least it wasn't something like breaking an axle
Old Nov 6, 2010 | 12:48 PM
  #125
Lets face it, its a 20 year old well driven gear set, i guess i should have seen it coming.
Old Nov 10, 2010 | 08:15 AM
  #126
Just got of the phone with East coast gear supply. Gonna get them to build me new F&R diffs with lockrites, and 4.88 gears
Old Nov 10, 2010 | 08:22 AM
  #127
irab88's Avatar
sweetness, dude. when?
Old Nov 10, 2010 | 08:24 AM
  #128
Once i get the estimate, ill move from there.
Old Nov 14, 2010 | 04:26 PM
  #129
Made some progress yesterday. Heading to the valve shop tomorrow to see what happened with it, because the gasket and physical condition is flawless. If i can get away with only one side, that would be nice, but i want to make sure that i don't have to go back later and do it. I have no problem with doing both, but my dad might. I've payed for everything including beer thus far, and did most the work, he just pointed and commented, so the chances of him being patient enough for both sides is not impossible.
Old Nov 16, 2010 | 06:16 AM
  #130
Just got off the phone with Ryan at East Coast Gear Supply. I purchased Front and Rear diffs with 4.88:1 R&P, Lockrites, a rear solid spacer, and triple drilled flange. Life is good. Not only that i should get the word on my head today, and get the motor going. After that im having 2.25'' straight piping done after i finish the motor. Things are happening, and quick.
Old Nov 16, 2010 | 09:38 AM
  #131
Mauzer's Avatar
Nice, hope everything works out smoothly
Old Nov 17, 2010 | 08:18 PM
  #132
Spanks!
Well, I got the word from the machine shop. Their shot, two valve jobs and shim placement is $1,100... That doesn't include gaskets, belts, timing belt, etc.
$1380 will get me a reman'd 3VZ-E long block, that comes with all the gaskets i need, a timing belt, and i already got the 2 V-belts and the serpentine.
So the conclusion is, i am going up to pull the block on Sunday (my step dads ranch in Warner Springs), and ill buy the new one on Monday, then have it in by the end of the week, i hope.
Not to mention i have my diffs on the way.
Old Nov 23, 2010 | 08:47 AM
  #133
And one more word.
Exhaust.
Old Nov 23, 2010 | 09:40 AM
  #134
rattlewagon's Avatar
Subscribed. I like your build. Keep up the good work.
Old Nov 25, 2010 | 12:59 AM
  #135
Thanks man!
Lots of progress!
Merry X-mas to me!
Old Dec 5, 2010 | 01:54 PM
  #136
rodeoman99@gmail.com
Guest
Posts: n/a
i would suggest cutting out the ashtray up front and mounting ur cb out of the way and it looks so much better
Old Dec 5, 2010 | 05:02 PM
  #137
But then you can't see the channel, and i like the way it looks now.
Old Dec 6, 2010 | 06:49 AM
  #138
Guest
Posts: n/a
yeah its all your preference where u want it, i had mine lke urs and i liked it so much better when someone told me how, i am always on the same channel so it doesnt bother me
Old Dec 6, 2010 | 07:40 AM
  #139
travis_h's Avatar
subscribed. nice lookin truck.
Old Jun 6, 2011 | 09:09 PM
  #140
tesseract620's Avatar
you ever get that new motor?
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Nickdigg
Jul 7, 2015 06:04 AM
zd92655
Jul 5, 2015 04:25 PM
