Mojave_Moze's 1987 4Runner Build-Up Thread!
Old Jun 29, 2011 | 11:54 PM
  #181
Mojave_Moze's Avatar
Been managing to get small things done every night this week, and even got some major steps out of the way.
So far, what HAS been done:
-Old parts comlpetely removed (Including: old tie rods, old ball joints, old UCAs and LCAs, torsion bars, old shocks, old idler arm, old pitman arm, steering stabilizer, and old power steering box)
-old droop stops completely hacked and ground off
-shock hoops/ towers welded on
-TC Upper control arm brackets cleaned/painted and prepped and ready to be bolted on
-TC lower control arms prepped and bolted on
-Steering linkage bar cleaned, painted, and idler arm bolt hole drilled to 5/8"
-Upper control arm bolt hole on spindles drilled out to 3/4"
STILL TO DO:
-Figure out max droop and weld on new droop stops
-clean and paint old steering arms
-clean and paint all welds and frame
-Calculate coil spring rate at the local Fab shop
-order col springs
-install new power steering box and new high-pressure line
-install new brake lines
-bolt on all replacement parts: lower ball joints, extended tie-rods, pitman arm
-bolt on upper control arms, new T-100 cv axles, cleaned/ re-greased spindles
-..get my coil overs once they're completely done
-tighten everything down to spec
-bleed brakes and power steering
-bolt on tires
-alignment
Everything should be done in about 2 weeks >.<
But until then, heres some teaser pics! The linkage bar and OME stabilizer are only on the truck for the mock-up
Its killin me having the rig on jacks this long, but the finished result will be soooooooooooooooooooo awesome!
Old Jun 30, 2011 | 08:07 AM
  #182
ChefYota4x4's Avatar
WOW, THAT'S ALOTTA DOOO'S AND DONE'S! LOL. Looking great! Oh, and NOOOOOOOOOO, I will not trade you my locker! hahaha. I need to clarify that, after cleaning up, ....I wasn't complaining, just stating what is most likely coincidence, but COULD be a factor... I mean, it's a bit more 'TUG' on things now, ya know? hahaa
Old Jun 30, 2011 | 09:23 AM
  #183
Mountain Cop's Avatar
Yeah, I guess I never stumbled across this one either. Good looking truck. Any more thoughts on the bedliner?
Old Jun 30, 2011 | 09:59 AM
  #184
irab88's Avatar
remind me why i'm not already subscribed....
nice work.
Old Jun 30, 2011 | 12:57 PM
  #185
Dunno why I didn't 'scribe to yours yet either man! Thought it was pretty cool how you brought that runner back from a firey grave!. Welcome to the "Blue Bomber" Thread
And chef: I was just teasin, just promise me you'll get out there and use that lunchbox soon as shes ready to hit the trails!
Old Jun 30, 2011 | 05:55 PM
  #186
twistedyota's Avatar
looks awsome man
Old Jul 1, 2011 | 01:02 AM
  #187
Took the night off as far as working on the yota today. Instead I had to go help a certain ex-yota owner friend..who made the traitorous switch to jeep-owner status...but, friendship is more important than what someone drives. No worries though folks! I still give him a hard time for driving a "Heep"
And heres more pics of teasers, and parts:
Upper control arms prepped and ready to be bolted on, plus welded and painted shock towers.
now THESE are bolts! Upper control arm to spindle knuckle mounting bolts to be exact
THESE lil thingies are what nearly put me dead in the water...although....the runner has been running without one of these spacers on the driver side for quite a long time, dunno if it caused any major issues, but, I'd rather be safe than sorry ya know? Come to find out, they're called "spacers" and go over the splines on the end of the cv shaft, between the end of the spindle and c-clip. Really hard to find parts, and not available at ANY local parts stores, so they had to be ordered from a factory parts dealer
Aside from probably getting Moog brand lower ball joints at some point, and the coilover shocks, heres the last of the parts I ordered that I needed to finish the build: New C-clips to keep the cv's in the spindle, new spacers, and new o-rings for the locking hub selector. The old ring seals were destroyed and weren't doing they're job anymore.
Old Jul 1, 2011 | 06:36 AM
  #188
now tht is beefy
Old Jul 1, 2011 | 11:07 AM
  #189
JonnyBoy's Avatar
Yeah, your welcome on the spacers! Anyway, where's these pics of the brake line routing over on the passenger side of the frame? And did you find the prop valve kit? I'm pretty sure it was FROR that I got it from.
Old Jul 1, 2011 | 01:40 PM
  #190
nvtoyota's Avatar
looks awesome man look at dirtco's turbo runner build for ideas on how to make youre front bumper stronger he did an awsome job
Old Jul 6, 2011 | 04:16 AM
  #191
jason in tn's Avatar
Just checking in on your progress moze, hope all is well and that your getting over all those little hurdles that seem to come up.
Old Jul 8, 2011 | 06:13 PM
  #192
The project came to a grinding hault recently, because 1.) The welding buddy took a vacation out of state, and 2.) The fab shop STILL hasn't gotten my coilovers yet, and we still have to tow the rig to the fab shop once the shocks DO come in so we can order the right coil springs...Shes at a stand still right now, but hopefully, will be finishing sometime in the next couple weeks. Everything else is pretty much done on the front suspension.
On a side note. I've decided to Enlist in the U.S. Army with the goal of going into the Rangers. Haven't signed anything yet, still gathering info and such. But Its only a matter of time before I go from civilian to soldier, and I'm really looking forward to it. The good news for you guys is the yota suspension upgrade should be completely done before I get sent off to boot, so no worries, I still have a lot of time. Felt ya'll should know though.
Old Jul 8, 2011 | 06:32 PM
  #193
cant wait to see pics.
and good luck in joining.
Old Jul 8, 2011 | 10:01 PM
  #194
Wow, good for you, Moze! THANK YOU for serving! Sorry bout your wait on the goodies! GRRR! lol.
Old Jul 9, 2011 | 08:45 PM
  #195
crongrats on the idea to sign up very admerable, hope you get alot done on the runner before you have to head out.
Old Jul 18, 2011 | 07:21 PM
  #196
Alright guys, managed to get some pics of progress. Which isn't much really. Again, parts and getting the welding buddies free time is still holding everything up. BUT heres what I got so far:
As for the update on enlisting. I'm not sighing anything until september, but until then, I'm on a special forces workout routine at my the local crossfit gym which is kicking my butt, lol. 5 days straight of grueling workouts, but nothing I can't handle!
More work will get done this week as I start buttoning everything up in prep for the arrival of the coil overs. which as it turns out, were ready to ship a week ago, the fab shop told F.O.A techs to double check the shocks, and discovered they were put together wrong, so it took an additional few days to get shipped, and when they DID ship...the guys at the fab shop were (are still) out of town working some huge 4x4 event >.< but again, stil plenty to keep me busy. I'll have more pics soon guys!
Old Jul 18, 2011 | 07:43 PM
  #197
looking good, now you're gonna have to paint the front diff to make it purdy like everything else haha.
Old Jul 18, 2011 | 08:10 PM
  #198
Wow, FLEXOMATIC! lol. Nice work, man!
Old Jul 19, 2011 | 08:27 PM
  #199
JonnyBoy's Avatar
Hurry up, I almost got 1 of my 2 rigs ready to go wheel! And don't worry, I'll take good care of your Runner while you're in boot camp. While you're at it, see if they need any helicopter crew folks...
Old Jul 19, 2011 | 08:46 PM
  #200
irab88's Avatar
mmmmmm... long travel ifs...
