lizard lips' 1991 Truggy Build-Up Thread
Old Mar 25, 2008 | 11:06 AM
  #41
yotasavg's Avatar
so you're ditching the quarter elipses? how did they work out for you?
is the leaf sprung front not going to be able to keep up with the rear or what?
Old Mar 25, 2008 | 01:47 PM
  #42
lizard lips's Avatar
The 1/4 ellips I'll probably run at first I have them and they are free. If I don't like them I'll just go with coilover or airshocks if I have to.
The front does have leafs right now. They are toy rears. They seem to flex really well. I have the same set as I do on my other truck and every toy I've built. I like to fly down the road to the next obsitcle. Linking the front will help with the bumps. Also no more axle wrap or wheel hop.
Old Mar 26, 2008 | 07:58 AM
  #43
more pics of the truss. still going to brace the middle of it
and my front links. 4130 chromo 7/8 heims, going to be replaced with some new ballistic joints
uppers 1.5" .250 wall
lowers 1.5" .250 wall sleeved with 1.75 .120
Old Apr 2, 2008 | 07:23 AM
  #44
some more updates. Took the toy cases off. Sold the dual case adapter, rear case and crossmember. Getting an adapter from OTT to put a dana 300 behind the first case. Just waiting on parts again.
Old Apr 2, 2008 | 08:50 AM
  #45
Tdubbs05's Avatar
quick and probably stupid question...why do you only have one ubolt on the right side of that front axle? it seems like you cant really get another one on due to the placement of the diff.
Old Apr 2, 2008 | 10:44 AM
  #46
The passenger side has 1 u bolt and the other has 2 holes drilled in the housing for studs or bolts. It's stock like that one 60's
Old Jun 7, 2008 | 11:50 AM
  #47
Some updates finally. Got the adapter I still need a c clip for the output shaft. Hopefully I'll have it all in this week.
And the dana 300
Old Jun 7, 2008 | 12:11 PM
  #48
abecedarian's Avatar
looks sick!!
would like to hear about how it rides. I'm concerned about the rear setup.
more pics!
Old Jun 7, 2008 | 12:28 PM
  #49
I was waiting to put the cases in and I'll finish up the rear. It should ride pretty well. I'll probably end up using coilovers in the rear
Old Jun 8, 2008 | 07:04 AM
  #50
just a 22re's Avatar
my god!!!!!!!!!!!!!!! wanna trade that why you can start over and get it done the way you want it??? lol no sorry lol
Old Jun 8, 2008 | 10:34 AM
  #51
I've changed my mind on a few things it would've been done if I hadn't changed my mind and had knee surgery
Old Oct 5, 2008 | 07:22 PM
  #52
Here's some updates finally. Got my 32 spline front and rear outputs. twin stick stuff. CPI harness and computer. greatlakes 14 bolt cover.
Had to redo the lower link crossmember
toy-dana 300 doubler up for mock up.
been working on my little brother matt's jeep Here's some other crap I got in for it.
32 spline front output for the dana 300
cpi 4.3 harness and comp
great lakes cover. Thick stuff
Old Oct 7, 2008 | 06:12 PM
  #53
fillsrunner4's Avatar
Sick
Good to see things coming together
Old Oct 7, 2008 | 06:23 PM
  #54
yotasavg's Avatar
looks like it'll be real nice! can't wait to see it in action
Old Jan 17, 2009 | 09:24 PM
  #55
Started to take the 60 apart. Don't forget to hit the pin out on the bottom side of the caliper to get the caliper off. Don't just hit the damn thing for an hour thinking what the hell am I missing.
and then once you get it off it looks like this in no time. Just a 100 pound rotor and hub.
Got the single wheel done and the high steer arms on. Oh and you can see the extra Chevy 60 I keep tripping over there too. :mrgreen:
And the new bling wheel and tire combo
Old Jan 17, 2009 | 09:25 PM
  #56
the 32 spline rear output. With flanges from High Angle.
And the dana 300 complete. 32 spline outputs front and rear. high angle flanges.
Old Jan 17, 2009 | 09:28 PM
  #57
Picked up 2 sets of 17" Bilstein coilovers. $600 for all 4. 2 are emulsion with dual rate and 2 are resevoir with dual rate and coils.
Also picked up four 4" fox bumps with cans for $200
Completed most of the truss. just going to add some braces and also tie the truss the the pinion bolt things and probably make my own pinion guard.
Made the lower links. 1.75 DOM .250 wall sleeved with 2.25 DOM .250 wall with Ballistic joints at each end
The last pic I have for tonight is the 44 boggers I put on the rear. It's at full bump right now. Test fitting coilovers and everything else.
Old Jan 18, 2009 | 02:21 PM
  #58
I also got a box of brackets for the front 3 link and a ifs toy box tapped for hydro for $100
Better pic of the rear truss without the bracing. I'm watching football and not working right now.
The rear at full bump
Old Jan 19, 2009 | 07:36 AM
  #59
80yotababy's Avatar
I love it!
Old May 10, 2009 | 06:16 PM
  #60
luxdlx's Avatar
And then?
SubiKing
Aug 21, 2021 03:57 AM
Gio8
Aug 27, 2015 12:14 PM
altydog
Jul 28, 2015 10:20 AM
Robojd1
23
Jul 21, 2015 01:43 PM
