lizard lips' 1991 Truggy Build-Up Thread
I picked up boogers old rid a while back and haven't done much to it lately. But I'm finally getting around to build it. The specs will be a cpi 4.3 a jet th350 and dual 23 spline toy cases with a 4.7 in the rear and marlins rotated adapter. here's the pics when I got it home.
http://i129.photobucket.com/albums/p...d-lips/2-3.jpg After I finished the spring hanger. http://i129.photobucket.com/albums/p...3020708131.jpg http://i129.photobucket.com/albums/p.../newrig004.jpg Started collecting parts for it http://i129.photobucket.com/albums/p...d/axles008.jpg http://i129.photobucket.com/albums/p...d/axles007.jpg http://i129.photobucket.com/albums/p...d/axles006.jpg 4.3 with air compressor out of the ac compressor http://i129.photobucket.com/albums/p...8tcase0004.jpg http://i129.photobucket.com/albums/p...8tcase0005.jpg Put some 38x15 boggers on it and moved it to my new house. http://i129.photobucket.com/albums/p...07pics0011.jpg http://i129.photobucket.com/albums/p...07pics0013.jpg |
I have the motor in but no pics yet. It was cold and dark.
Here's the cases http://i129.photobucket.com/albums/p...18pics0008.jpg Kinda prepped under the hood, with the gm master cylinder http://i129.photobucket.com/albums/p...18pics0006.jpg |
Here's some more updated pic.
Motor mounts in http://i129.photobucket.com/albums/p...19pics0017.jpg The motor still is going to be moved back about 3-4" http://i129.photobucket.com/albums/p...19pics0015.jpg http://i129.photobucket.com/albums/p...19pics0016.jpg Front spring hanger http://i129.photobucket.com/albums/p...19pics0018.jpg http://i129.photobucket.com/albums/p...19pics0014.jpg Box and steering http://i129.photobucket.com/albums/p...19pics0013.jpg |
nice work. i bet its gonna be sick!!
It should be pretty good once I get the wiring finished.
thats going to be sick.
why the gm master cylinder? |
So I can actually stop better. 1 ton brakes makes it easier to stop with a toyota booster and 1 ton axles
Should have the dana 44 out and the 60 in this weekend
tubing material. 1.75" DOM .250" wall, and 1.5" DOM .250 wall. http://i129.photobucket.com/albums/p...inished001.jpg Radiator I'm using. For a nova or chevy II 28" wide, 18.5" tall and 2" thick at the radiator and 3" thick at the tanks http://i129.photobucket.com/albums/p...inished002.jpg |
Some updates for you all. Here's some pics of the rear tubework
http://i129.photobucket.com/albums/p...27pics0001.jpg I'll have the rear axle sitting about where it is when I'm done http://i129.photobucket.com/albums/p...27pics0002.jpg Under the motor http://i129.photobucket.com/albums/p...27pics0016.jpg http://i129.photobucket.com/albums/p...27pics0015.jpg Sky's offset shackles http://i129.photobucket.com/albums/p...27pics0012.jpg http://i129.photobucket.com/albums/p...27pics0013.jpg Waiting on the 60 http://i129.photobucket.com/albums/p...27pics0011.jpg to put in http://i129.photobucket.com/albums/p...27pics0017.jpg |
them there rear springs look a little funny you flip them and cut them or what? cause it looks like you did never really saw that on a truck before yet again this is far from a truck now lol good job man i love it!!
rear 1/4 ellips are 57" ford cut in half using the long side.
1/4 ellips buckets.
http://i129.photobucket.com/albums/p...ld/0129012.jpg http://i129.photobucket.com/albums/p...ld/0129010.jpg Cut the rear axle off. Swapping it with my other axle on my other truck. Need to build the truss and weld the link tabs on. http://i129.photobucket.com/albums/p...ld/0129008.jpg http://i129.photobucket.com/albums/p...ld/0129009.jpg |
Got the 60. I just need some spring plates and ubolts.
http://i129.photobucket.com/albums/p...ld/axle002.jpg |
making room for the new tank.
http://i129.photobucket.com/albums/p...ld/0129002.jpg |
WOW. What an awesome project. You hit the lottery or something?
Are you mounting the radiator in the back? |
No, no lottery winner here. I sold off parts I had from my last truck to fund everything so far. Well mostly. The radiator will be in the front. The motor will be moved back about 3-4 more inches.
such an awesome truggy.
This project is AWESOME.
thanks guys. I'm going to pick up some more 60's this weekend. Probably going to use one of the ones I'm picking up. it's a single wheel version.
