LGcrawler's 90 singlecab build-up thread
Old Jan 6, 2012 | 08:27 PM
  #81
john4wd's Avatar
I like how your using the factory bumper brackets in the new bumper, well that's what they look like to me :}
Old Jan 6, 2012 | 08:37 PM
  #82
LGcrawler's Avatar
Yup, I used the factory brackets, I didnt want to fab up some haha and the factory ones are like 3/16" thick so pretty beefy to build off
Old Jan 22, 2012 | 07:49 PM
  #83
cdpsc22's Avatar
LGcrawler... Check PMs buddy.
Old Feb 7, 2012 | 12:12 AM
  #84
LGcrawler's Avatar
Originally Posted by RHL Yota squad
That's a bad ass tire rack did you buy that or make it?
Thanks, Ya I built it when i was learning to weld last year, turned out alright
Old Feb 7, 2012 | 03:38 AM
  #85
racerflea's Avatar
Truck looks good!!!
Old Feb 21, 2012 | 07:59 PM
  #86
hondacr57's Avatar
Originally Posted by LGcrawler
so ive been building a rear bumper out of some 1 5/8ths tubing , what do yall think?
and heres a recent pic of my truck
Are you running wheel spacers up front that thing looks like it sittin wide? Sweet rig btw.
Old Feb 21, 2012 | 08:33 PM
  #87
LGcrawler's Avatar
Ya 1.5" wheel spacers up front
Old Feb 22, 2012 | 01:41 PM
  #88
Stewmaker95's Avatar
Truck looks sweet man. Ya need some blazeland love for that front
Old Feb 22, 2012 | 02:31 PM
  #89
LGcrawler's Avatar
Thanks man, ya wish I could get blazeland. Just not in the budget right now haha but maybe some day
Old Mar 15, 2012 | 10:47 AM
  #90
LGcrawler's Avatar
The yota started idling high and when you put On the brake it will drop from like 1500 rpm to 800 then back up and down up and down until I let off the brake and it will idle at 1500 again. I replaced the TPS and it still did it. I cranked the idle down by using the screw on the throttle body but it just runs too rich and the check engine light came on, any suggestions?
Old Mar 15, 2012 | 11:59 AM
  #91
4.0 Pickup's Avatar
I would check the vacuum hose that goes from the intake to the brake booster. Might be cracked. This sounds like a vacuum leak or idle air control valve.
Old Mar 15, 2012 | 12:11 PM
  #92
LGcrawler's Avatar
Thanks man I'll check that out tonight
Old Mar 15, 2012 | 04:43 PM
  #93
A2theK's Avatar
Sweet looking rig man, love the front tubing bumper. Thinking about making myself one. Where did you get your front spacers at? Might have missed it, but I saw that they were 1.5" big, did you crank your torsion bars too?
Let me know if you find out your idling issue! Mine has been acting up with the same exact problems, driving me crazy..
Old Mar 15, 2012 | 06:04 PM
  #94
LGcrawler's Avatar
Thanks man ya it has 1.5" 4crawler ball joint spacers, I didn't crank the torsion bars. The fiberglass is what makes it look like alot of lift up front. Hopefully I figure this idle issue out soon. I need to smog this beast
Old Mar 20, 2012 | 06:18 PM
  #95
tacotacoma96's Avatar
Thumbs up
Sweet truck. I'm Building up my 1994 pickup. keep up the great work. also what is the rim size? are they 15x7 or 15x8? Rims are my next step.
Old Mar 20, 2012 | 06:41 PM
  #96
A2theK's Avatar
Just letting you know that I had this problem for a while now and I burped the air out of my coolant system the other days and I've had no problems with idling issues so far. Good thing to look into!
Old Mar 21, 2012 | 08:40 PM
  #97
LGcrawler's Avatar
thanks man, ya the wheels are 15x8 with 3 3/4" backspacing i beleive
  #98
LGcrawler's Avatar
alright ill give that a try, im thinking it also might be the coolant sensor. thanks for the advice
Daenerysdad
Oct 1, 2015 07:33 PM
joeynational
Sep 5, 2015 01:54 PM
86 87 4Runners
Sep 5, 2015 06:02 AM
Ryall
Sep 2, 2015 06:48 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
