lazlow's 1989 Pickup Build-Up Thread
Old Jan 3, 2010 | 10:28 AM
lazlow's Avatar
Hey im 17 years old and sorta new to the forum but ill post up what i have so far of my truck. I traded my cousin a 1993 full size blazer which i got for free and 1500 for his toyota with a 350 in it. Can probably imagine my excitement when getting it haha. Its a pretty awesome project for me and it stands out a bit with me living in NJ. Paint is a little meh...but ill live. And sorry for the not amazing pics. This is from when we first picked it up.
There were a few things wrong with it. The steering shaft was stripped where it connects to the box so i replaced that and had to put an extension in because they didnt when doing the body lift, had to modify and reattach the sway bay, my dad fixed the electric fan for me, and i had to get the radiator fixed the right way(jb weld doesnt hold forever). So it ended up lookin the same on the outside.
You can see some rust on the rocker panel so i picked up a new one from the junkyard for $100. More like a half a cab lol but im waiting to get it to a body shop.
Then of course i had to have some fun with it
Here is where im currently at. Had a few motor problems and got them sorted out. They had an 8 gallon fuel cell in the bed before me so i took that out and put a tank from a 4runner in there. That caused problems with the internal fuel pump in the tank and the tank was dirty as hell so i have a new one coming soon from rockauto.
The motor
Put a cheapo summit tach in after the older autometer one broke
The interior
And my welder and torches. overkill with a trailerblazer 302 but i dont mind haha
Old Feb 20, 2010 | 10:24 AM
de6w6it's Avatar
Lookin good my friend, what trans are you running?
Love the colors!
Old Feb 20, 2010 | 10:57 AM
lazlow's Avatar
its got a turbo 350 trans but still a stock yota case. I actually like the purple cause its different. You know any wheeling spots around here?
Old Feb 20, 2010 | 11:08 AM
de6w6it's Avatar
nice
yeah i wasnt kidding, def diggin the colors, kinda 80's looking
no, not really. i've taken my jeep to Rausch Creek out in PA a few times, but the yota, being the DD, hasn't seen the trails yet, but nothing around here.
Old Feb 20, 2010 | 11:38 AM
lazlow's Avatar
thanks, people usually dont like the colors. Yeah i was thinkin Rausch creek was the closest, oh well. This and my ranger are both my daily drivers so i try not to beat it up to bad either. If you wanna meet up sometime it would be cool cause i havent seen a yota sas up close yet.
edit: might as well add an update. A couple days ago goin down the highway and my driver side rear bed mount broke. temp fix was a strap...
so then i tig welded a block up out of aluminum and drilled a hole and put it in its place. seems to be workin good.
Old Feb 20, 2010 | 02:48 PM
de6w6it's Avatar
that looks sweet man, awesome welds!
i'm up for meeting up sometime, gimme a holler
Old Apr 12, 2010 | 11:43 AM
lazlow's Avatar
well a small update. I got some new tires...36x12.5 super swamper tsl's my jack was barely tall enough to get the truck high enough for 36s. I think they look pretty sweet and fit the truck good. btw mounting these tires are a bitch lol its a good thing my friend did it for free
Old Jul 2, 2010 | 06:47 PM
lazlow's Avatar
a little update...i decided to make some tube doors cause i got bored. So heres some pictures i took.
Pipe bender im using
the top tubes, one for each side.
plate that i cut out to mount the tubes on the hinge
plate on the hinge. The plate flows with the body lines for the most part and it should keep rocks or dirt from coming off the tires and through the fender.
and then all the tubes on and fully welded. I still have to weld on my latch and finish mounting and welding the other side. I felt tube doors were a good addition for the summer and i plan on leaving it like this until it starts getting cold again.
Old Jul 2, 2010 | 08:15 PM
Chedo2.0's Avatar
dude, I love your bumpers haha, good lookin truck!
Old Jul 2, 2010 | 09:25 PM
89silverpu's Avatar
Nice job on those tube doors! You gunna rip the front end off and upgrade to 1 tons? You're going to want to if that 350 has any kind of power...
Old Jul 4, 2010 | 10:46 AM
lazlow's Avatar
thanks. id like to go to 1 tons but im going off a high school(well college now) budget and i just bought a holley truck avenger carb(about $380) because my edlebrock sucked at anything but flat ground. Im just running it till it breaks but im not doin any crazy rocks just quad trails and mud so things are holding up good.
Old Sep 23, 2010 | 04:27 PM
lazlow's Avatar
and so it begins... picked up a solid axle from a 1985 with 4.10 gears for $150 going to order the trail gear 5'' hd kit soon
Old Sep 25, 2010 | 05:20 PM
85gijunk4x4's Avatar
subscribed!! ill be looking for your truck wherever i go, lol and it does stand out. keep up the good work, youre great at fabricating. i cant wait to see what happens next!
Old Sep 25, 2010 | 05:31 PM
91_TOYOTA_4x4's Avatar
cool yots dude. color is a little weird but owell lol. glad to see you are sasing ifs is just poooooooo
Old Sep 27, 2010 | 03:28 PM
de6w6it's Avatar
hello there my friend, good score on the axle!!! gimme a shout if you need a hand with anything, for sure
btw...those tube doors are super sweet!
Old Sep 29, 2010 | 06:18 PM
lazlow's Avatar
thanks, ill hopefully be ordering my kit soon for it so ill probably shoot you a call after it gets here. And thanks i really like the tube doors. If i made another set id do it differently but its all a learning process lol.
and ive changed plans on the lift spring height. 5" springs plus my body lift would be way to tall for my taste so im going to go with 3" springs and maybe mix and match heavier springs if the motor weight is too much for them. Id rather not mess with my body lift because of the motor so hopefully the shorter springs will help lower the truck a bit. 36s will stay but next set of tires will be more street friendly 35s or 36s
Old Sep 30, 2010 | 03:48 PM
de6w6it's Avatar
sounds good man. you could make 3 inch springs clear the 36's, but you wont have much to worry about with the body lift in there too. the body lift will also come in handy if you decide to lift the drivetrain to get a flat belly. as for the extra motor weight, add a leaf and/or make the shackle slightly more vertical and you shouldn't have any issues.
def gimme a ring, id be more than happy to give ya a hand
Old Nov 8, 2010 | 10:37 AM
lazlow's Avatar
not really a big update but some new pictures. pic of engine bay...its dirty and the wiring looks bad but ive cleaned that up since then. new carb is a holley truck avenger which is pretty dam good.
next is a pic of the exhaust cutouts i added before the mufflers. very easy to change even when exhaust is hot. crappy pic but im still only using my camera phone.
also went wheeling yesterday and some vine got caught under the axle and my idea was to gas it and break it but...nah it just broke my fender flare. kinda funny thinkin that a vine was holding the truck enough where it was struggling to move
ill have enough to order my sas after my next paycheck. its a good thing i had to wait because trail gear just came out with 3" hg springs which is what i want.
Old Dec 16, 2010 | 06:57 PM
lazlow's Avatar
bye bye ifs! I have to thank wabfab for the awesome deal on the kit and good customer service. Would recommend him for sure
Old Dec 16, 2010 | 07:01 PM
874runnersr5's Avatar
sick build!
im digging your welder setup
