JelloJacks 95'4runner build-up
Old Apr 26, 2013 | 05:35 PM
JelloJack's Avatar
Had the old 4unner since 02' just now gaining a renewed interest in the green bastard, slapped on a trail gear bumper ready for new tires. Think I'm going with 31" duratracs
Attached Thumbnails JelloJacks 95'4runner build-up-042413151103_zps9eddc23c.jpg   JelloJacks 95'4runner build-up-042413151013_zps2a85ab1b.jpg   JelloJacks 95'4runner build-up-042413151030_zpsbd45e9b4.jpg
Old Apr 27, 2013 | 12:35 PM
Jagger_MeisterJE's Avatar
The green bastard parts unknown! hahaha
Joking aside you've got yourself a clean rig man! I'll be following along on this one!
Old Apr 27, 2013 | 07:11 PM
JelloJack's Avatar
Ha, bubbles....funny thing is I do live in a trailerpark.
I've got sum more pics of stuff I've aleady done on the 4runner or will be doing shortly,
Flexalite blackmagic electric fan with in cab switch and thermostat, done
Isr mod with blue silicone vacuum hose kit is next followed by water temp.gauge, voltmeter gauge, oil pressure gauge, installed in a three pillar pod. And 2000+watt stereo installed. Its my daily drivier for now. All new upper lower balljoints, inner outer tierods, centerlink recalled, pitman arm idler arm with brass bushings, swaybar endlinks, poly swaybar bushings, upgrade rear swaybar, dynomax exhaust walker cat, o2 sensor, water pump, timing belt, idlers, clutch fan bracket etc., just trying to keep the green bastard going
Old Apr 28, 2013 | 05:58 AM
kornhuskerwizard's Avatar
Nice build!! If your runner will pull your trailerhouse its worthy!!
Old Apr 28, 2013 | 12:10 PM
JelloJack's Avatar
Got sum more pics of bumper. Its a trail-gear low pro bumper with welded on light bar and tabs for a pair of kc daylighters, welded led signals, spiderweb gussets, and end spikes painted a rustoleum flat iron metallic. I think it turned out purrty.
Attached Thumbnails JelloJacks 95'4runner build-up-042813130444_zpse54d6b07.jpg   JelloJacks 95'4runner build-up-042813130353_zpsd0634d97.jpg   JelloJacks 95'4runner build-up-042813130524_zps7ee81cb2.jpg
Old Apr 28, 2013 | 12:18 PM
JelloJack's Avatar
If a tundra can tow a space shuttle, I'm positive my 3.0 can pull a single wide trailer! Haha
Seriously though when I moved to Austin a few years back I was starting a new job and my apartment wasn't ready for a week after I started my job long story short I had to tow all my ˟˟˟˟˟ 200miles for a week in a U-Haul from my hotel to work every week cause it was cheaper then getting a storage unit for a month and only using it a well it had to be 5000lbs in that U-Haul and the 4runner could pull it 70mph down the freewuay. Haha
Old Apr 28, 2013 | 12:27 PM
JelloJack's Avatar
More pics
Attached Thumbnails JelloJacks 95'4runner build-up-042813130504_zpsa4a6d64e.jpg   JelloJacks 95'4runner build-up-042813130546_zps3fff4d64.jpg   JelloJacks 95'4runner build-up-042813130429_zps6b97db21.jpg
Old Apr 28, 2013 | 12:39 PM
JelloJack's Avatar
Exhaust, silicone vacuum hose kit for 3.0-thanks Lcengineering
Attached Thumbnails JelloJacks 95'4runner build-up-042813131047_zpsdd712784.jpg   JelloJacks 95'4runner build-up-042813131116_zps5125aacf.jpg   JelloJacks 95'4runner build-up-040813235137_zps75de12ae.jpg
Old May 1, 2013 | 01:04 PM
JelloJack's Avatar
Got sum switches from OTRATTW. They look awesome. Installed one for the Kc's in one of the coin holders in the center console fit perfectly no modification necessary and the coin tray popped right out. Definitely gonna order a couple more. Maybe on labled ZOMBIE LIGHTS for roof lights I plan on running on a light bar and maybe sum additional reverse lights in the back should help illuminate a reverse camera. So many parts too little time and money. Way of the world. A winch would look killer in there behind the lights. Christmas is over 6 months away dammit
Attached Thumbnails JelloJacks 95'4runner build-up-050113150719_zpsc726b5dd.jpg   JelloJacks 95'4runner build-up-050113150737_zpsa72d37bb.jpg   JelloJacks 95'4runner build-up-050113150234_zpsfaed750e.jpg
Old May 2, 2013 | 11:39 PM
JelloJack's Avatar
Running boards
I decided to remove the running boards today still unsur if I like or not. Took all of 10 min. 6 bolts and they slide off. It will probably look a whole lot better when the new rubber comes in.
Attached Thumbnails JelloJacks 95'4runner build-up-050213185656_zpsd4aea850.jpg   JelloJacks 95'4runner build-up-050213185714_zps6ab2a950.jpg   JelloJacks 95'4runner build-up-050213185746_zps111784a7.jpg
Old May 3, 2013 | 03:31 AM
I like your zombie switch
Old May 4, 2013 | 04:13 PM
JelloJack's Avatar
speaker system
Probox rhino-lined for 3/ 10"subs , tweeters ,coaxials, 1200watt mono digital amp
Attached Thumbnails JelloJacks 95'4runner build-up-042813131633_zps86a74d8c.jpg   JelloJacks 95'4runner build-up-042813131730_zps3b1552dd.jpg   JelloJacks 95'4runner build-up-022413013145_zps0dda50d1.jpg
Old May 5, 2013 | 01:53 PM
JelloJack's Avatar
speaker system
Boom boom
Attached Thumbnails JelloJacks 95'4runner build-up-022413012717_zps99683ca4.jpg   JelloJacks 95'4runner build-up-120412120019_zpsa5eef09d.jpg   JelloJacks 95'4runner build-up-102512204728_zps0e248f98.jpg
Old May 5, 2013 | 10:16 PM
JelloJack's Avatar
Im in the process of doing Sooo....many things to my truck cant wait til its all done. I got this badass 3gauge A-pillar mount holder going with phantom2 gauges. already have the holder full blue led gauge lighting white gauges, brushed aluminum gauge bezel, dash overlay kit either in gray burl donod, or carbon fiber not really going for the ricer look. more custom willl be done in the next month after wheels and tire come in just debating on 33's or 31's. worried bout gearing and fuel efficiency seeing how i still get 17-20mpg regulArly. but idk im definety uping to 4:88s sometime this year and a locker. kinda want the best of both worlds any opinions ??????
Old Sep 8, 2013 | 09:59 AM
JelloJack's Avatar
Goodyear duratracs
clean
Attached Thumbnails JelloJacks 95'4runner build-up-2013-08-12184418_zps705ade3c.jpg
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
