James Dean's 1993 4Runner Build-Up Thread
Hey James the biggest issue with them fender flares is they catch to much rock and gravel and keep it in them causing the fenders to rot out faster. I would if I were you run a bead of black silicone around the edges of them where rocks and dirt could get in to help stop as much of it as possible and keep them fender wells in the shape their in now for years to come.
3rd Brake Light Addition
Since the 3rd brake light wasn't standard till 94 and I tow on a regular basis I thought the addition of a 3rd brake light would be a good safety addition. wii tarded had purchased a wrecked 95 from a used car lot that had a good brake light. He was kind enough to sell it with the wiring. It was green so I had to paint it to match, no problem there. I made a paper template to locate the holes for the two mounts and for the wire harness. After re-gluing the rubber seal in place and putting some RTV sealant around the bolt holes I set the brake light in place and tightened it down. Fortunately the 93 4Runner came with the 3rd brake light plug already in the harness, so all I needed to do was plug it in. The addition of a 3rd brake light on my 93 was complete. All that is left is to trim my rear air deflector to allow for clearence.
Jun 1, 2021 01:51 PM
