iamsuprman13's 93' Toyota Pickup Extracab 4x4 V6 AT Frame Up Rebuild
Old Nov 26, 2011 | 07:54 AM
  #81
iamsuprman13's Avatar
Thanks...it is already a pain in the behind, thankfully I am really good with wiring schematics, since I use them all the time at work...
Old Nov 28, 2011 | 09:19 PM
  #82
Lewis15498's Avatar
First of all thank you for your service to this country!
Awesome progress, the 1UZ was indeed an excellent choice. We're working on the same truck, feel free to check out mine (link in my sig). I dont envy your rust situation, but clearly you're not scared of it.
I'm 95% sure that white tube behind the passenger fender on page 1 is related to the antenna. So unless you're ordering a new antenna from toyota, I wouldnt worry about it.
Old Nov 28, 2011 | 10:24 PM
  #83
RMP8080's Avatar
iamsuprman13 I have to ask, did the truck come from New Jersey?
anyway, great job so far, waiting to see the completed vehicle, good luck
Old Jan 19, 2012 | 07:37 AM
  #84
93ToyYota's Avatar
Sub'd
Old Jan 19, 2012 | 08:41 AM
  #85
So sorry everyone, about the lack of posting....I have been super busy as usual....then went on Christmas leave to California...which was fun, but damn did I wish I had my truck to wheel...so since I have been back I have done a little work on it...but all I am doing now is frame work...trying to get the frame all sandblasted, and repaired...I have to replace two crossmembers, and patch a couple holes...thankfully nothing is too bad...the biggest problem I am having is my compressor is weak and my sand blaster is small so it is taking me some time...but soon, I think this weekend my frame will be completely done...I will get some progress pics up soon, but deployment is coming up so soon...I have less than two months before I leave...so my plan is to at least have the frame and cab repaired...and since I am still making plans on what direction I fully plan on taking this rig...I will have this whole deployment to buy what I need and plan everything, step for step...
Old Jan 21, 2012 | 05:24 AM
  #86
alcs's Avatar
Talking
Just want to be part of the progress
Old Jan 21, 2012 | 09:59 AM
  #87
ChefYota4x4's Avatar
Stay safe out there, Superman! Nice progress.... can't wait! Love the pic in the living room and the 'sniff test' going on! hahaha.
PS> Can you borrow a bigger sand blaster from A1 Rentals(or some place like that near you?). Might save you DAYS! lol.
Old Jan 23, 2012 | 03:38 PM
  #88
90bulletproof_PU's Avatar
subscribed, cant wait to see this thing all done
Old Jan 25, 2012 | 03:57 AM
  #89
Thanks me either, however it will be awhile...which I know it already has been awhile...it really sucks when you want to work on it but don't have the time...and then when you have all the time you need but don't have the money! If it weren't for those issues this baby would be done...but of course you could say that about everything...lmao "If only I had more time and money...." However, with the deployment I will be bringing in a bunch of money so, my plan is to order and have most of what I need shipped home, my wife is just gonna put it in the garage for me...so when I get home I will have a garage full of goodies to work with...it's gonna be awesome!
Old Jan 25, 2012 | 07:38 AM
  #90
RMP8080's Avatar
I friend of mine was deployed and the whole time he was there he was ordering parts so when he got home his room was completely filled, now he back playIng with the new toys.
Good luck
Old Jan 29, 2012 | 02:43 PM
  #91
That is the plan, I have been writing up and drawing up plans for the truck so that I have a good idea of what I need to accomplish it...I will be ordering parts and tools for it and I can't wait until I can get back and get back to work on it...I haven't even left yet and I am super excited about it...I have had the truck for almost a year now and because of lack of time and money I have driven it less than 100 ft (onto and then off of the trailer) but I have seen it go from a full (well almost full due to the cancer) truck to a bare frame, my hope is to have the frame restored and the cab resto began in the next month before I go, that way when I get back I can finish rebuilding the motor and start putting everything back together...I have so many plans for the truck...I cannot wait to see the truck start coming back to life...so thanks to everyone who has been watching my progress, and I really hate to have to leave it for so long, again...but that is the price we pay to "serve our country" but I will be keeping up to date as much as I can with my purchases for the project...that way you guys can share in my anticipation for when I get back!
Old May 22, 2012 | 03:20 AM
  #92
So while I am out here in Afghanistan not able to work on it...I thought I might as well take this chance to post up a list of parts that I need. I am going keep this a running list, so I can change, add, and update as I go!
So here it goes:
1UZFE - Got it!
R150F or R151F
VF1A
1UZFE ECU - Got it!
Bellhousing - (the bellhousing from the 1UZFE tranny)
Adapter Plate - (from bellhousing to tranny)
Dana 60 High Pinion Front Axle
Dana 60 Rear Axle
Driver Side Drop Rear Case
17" Wheels
between 37" and 40" Tires
Front and Rear Lockers - (Electronic Controlled)
Radiator, Aluminum Multi-core
Custom Driveshafts
Electric Puller Fan
Clutch Components - (Master Cylinder, Pedal, Release Cylinder, Clutch, etc...)
Bigger Brake Master Cylinder
Flywheel - 5VZE
Alternator - (12/24 volt output)
AC Compressor + AC Components (Condenser, etc...)
EGR Delete Kit
Crankshaft Pulley
Water Pump - Got it!
Timing Belt w/ Idler Pulleys - Got it!
Complete Engine Gasket Set - Got it!
PS Pump
Remote Oil Filter Kit w/ Filter
Headers - (Tundra)
Thermostat
Spark Plugs
Sparkplug Wireset
Distributor Caps and Rotors
Drive Belt
Drive Belt Tensioner
Timing Belt Hydraulic Tensioner
Rod Bearing Set
Main Bearing Set
Thrust Bearing Set
Piston Ring Set
Piston Pin Bushing Set
Engine Plastics
Custom Exhaust
Valve Shims
Oxygen Sensors
Replacement Rocker Panels
Replacement Bed Sides
Replacement Fenders
Cold Air Intake
MAF - Got it!
Reduction Box
Dual Case Adapter
4.7:1 Gears for the Transfers
Up to 7.17:1 in the Axles
Dual Optima Yellowtops for 24V system
Plumbing for Everything
Custom 3 or 4 Link Front and Rear w/ Coilovers
Steel for Cage (Front to Back), Bumpers, Sliders, and Custom Rear Frame
After I get home and I have a chance to inspect I may need:
Intake and Exhaust Valves
Rod Bolts
Main Bolts
Head Bolts
Oil Pump
Pistons w/ Wrist Pins and Clips
Valve Springs, Bushings, Retainers, etc...
Injectors
Ignition Coils
That is a pretty good list for now...I have a few things already and I will update as I get more, or think of more.
Old May 22, 2012 | 03:22 AM
  #93
So just by looking at that list you guys can pretty much tell what my plans are...I have spent the last two months of deployment using all my extra time drawing up plans, working on the wiring schematics, and looking for parts...so hopefully with this list I can actually start putting my goals into action!
Old May 22, 2012 | 05:32 AM
  #94
hiemsnox's Avatar
nice project!, Good luck Over-seas and be safe!
Old May 22, 2012 | 06:14 AM
  #95
irab88's Avatar
'scribed.
Old May 22, 2012 | 09:31 AM
  #96
Hey Superman, ....SUP? Hope you're safe/doing well as is expected over there
I saw you post "R151F" in your list..... PLEASE, if you find two, tell me, I'll ship you the cash and have you grab it and ship it to me? hehehehehe. Can't find one to save my life in L.A.! lol.
Old May 22, 2012 | 10:51 AM
  #97
Hell, I can barely find R150F's for a good price anywhere...everywhere I look it is the W series trannies...and yeah I think they are good and all, but not what I want!
Old May 22, 2012 | 11:19 AM
  #98
TOTALLY understand that. My 4th gear Syncro is toast.... it still goes in but HEHEHE. So, I figure, "why not slap in a trans that WILL handle the 1UZ or whatever swap I one day play to do"? I know you can get one in L.A., reman'd..... but HOLY CRAPULA! Pricey haha.
Old May 22, 2012 | 12:43 PM
  #99
Yeah I have found alot of them that are hella expensive...thats not for me though...so always on the lookout for a good deal
Old Mar 31, 2013 | 06:58 PM
  #100
tpurkey's Avatar
Did you finish the truck?
