Customer Feedback For Vendors Use this forum for feedback good or bad on vendor's & dealer's you have dealt with
FlameThrowers 22RE Injectors 89-95
Old Jul 26, 2013 | 05:31 PM
Toyota~Boy's Avatar
Hello everyone.... About 2 Weeks ago I spoke with a member of this site by the name of Flamethrower. He had a new line of fuel injectors that he was selling. He was looking for 10 candidates to try out these injectors and give a thorough review of there performance. I was one of the lucky few that got a chance to try these out. Below I'd my review.
My truck is a 1993 Toyota pickup. My engine is a 22RE backed by a W56 5Spd tranny. I'm running 33" tires with 4.88 gears. My truck is a DD so it sees a lot of highway usage.
My truck has a brand new fuel system. Fuel tank, fuel lines, fuel filter, fuel regulator, and fuel pump. This stuff was installed about 2 weeks prior to receiving these injectors so my review will be for optimum performance.
I received my injectors via USPS along with a new upper plenum gasket. So nothing else was required besides your basic tools and knowledge. Installing was a breeze. Also supplied with the injectors was a new plug and play wiring setup do to a different plugin on the injector.
Once installed a cranked my truck over a few revolutions until it started. Once running it idle fairly high until the cold start injector disengaged. After that I idled roughly at 600R. It loped at 450-500RPM prior to installing. I noticed while idling it was much smoother then before. Once revving the engine it was really crisp. No hesitation at all. Now once I checked and made certain of no leaks I test drove my truck. Upon on acceleration it was much quicker. Seemed as I was grabbing gears a lot faster then normal. Now I'm not saying I was pinned in my seat by power but it felt really good. I was highly surprised at what new a difference these injectors made.
Now for the fuel mileage. This was based off a complete fill up to empty calculation. I was getting around 272 miles tank. That's roughly 16 MPG highway. I'm only done this once since installation and I've noticed a 3-4 MPG increase. I'm now getting around 325+ Miles per tank highway. Now I think that's pretty good for my setup. I'm sure if I was running a 235 with 4.10's it would be better but O well.
For anyone looking for a upgrade or just need new injectors I'd highly recommend these. I do no that they are offered for both the 22Re and 3.slo.
I'm going to conclude this review and if I should have any problems with these in the future I will add it to this review. As stated I'm highly satisfied.
Old Jul 28, 2013 | 02:56 PM
Toyota~Boy's Avatar
Included a vid
Old Jul 31, 2013 | 06:51 PM
Flame Thrower's Avatar
FormerVendor
Anyone who is interested in these injectors can click on the following link:
https://www.yotatech.com/forums/f37/...ectors-271525/
Old Jul 31, 2013 | 07:07 PM
Toyota~Boy's Avatar
I want to thank you for the opportunity to use these injectors. There's not very many people like you anymore. I really put these to the test to. I drove a little over 500 miles from WV to NJ pretty much non stop and I had no problem at all. All the info on my trip is in my build thread.
Doug4320
Mar 24, 2018 10:11 PM
JustMike
Apr 21, 2016 07:08 PM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
