Doomys 87 Turbo 4runner Build thread
Old Jul 26, 2021 | 08:56 AM
  #781
RBX's Avatar
RBX
I hooked up my 4wd light in the dash, but I can’t remember what wire it was. The info should be in my build thread when I did the manual swap.
Old Jul 28, 2021 | 08:03 PM
  #782
BigBluePile's Avatar
Hell ya! Yoyoyoyo! Slap hands!!!
Old Aug 4, 2021 | 07:23 AM
  #783
space-junk's Avatar
switching gears for a moment since my mind wanders, @RBX , are you happy with your Cobra Towers from 4WU? Im thinking about running them for my LT setup im installing since they come with provisions for limit straps and they are pretty compact. not a fan of the Trail-Mart hoops that most run and TC shock hoops are STUPID EXPENSIVE.
although i have yet to confirm, the PO of the LT kit believes these are the specs of the shocks(although the shocks are the older Blue andonization instead of black): https://www.ridefox.com/product.php?...ber=980-02-016
i think that theyd pair nicely with the Cobras. https://www.4wheelunderground.com/product/cobra-towers/
thoughts?
Old Aug 4, 2021 | 07:59 AM
  #784
RBX's Avatar
RBX
Love my 4WU 3-link with cobra shock mounts, however they mount on the top of the frame and would intercept with the torsion bars. But if you are going coilover this shouldn’t matter.
Old Aug 4, 2021 | 08:15 AM
  #785
space-junk's Avatar
oooooh...good point. didnt even think of that. its not the T-bars that would interfere, its the whole upper control arm mount!
ok, well then...guess TC it is? thats gonna set me back about 600 bucks.
Old Aug 11, 2021 | 07:34 PM
  #786
Looks amazing!
Old Sep 28, 2021 | 08:40 AM
  #787
space-junk's Avatar
Guess i havent posted in a while. Oops!
Ive got the transmission in my possession. And i have almost every part to complete the swap. went with the larger flywheel off the newer w56 trucks and a matching 1200lb marlin clutch. I found a company out here called Tea Garden Motorsports who made me a 5' Braided steel line to bridge the master and slave. Ive got a new throw out bearing and pilot bearing as well as new grease boots for the shift fork and both shifters. I found a guy selling a 5 speed SR5 Shifter surrpund and leather boot that wasnt cracked(small holes drilled, but im ok with this) and im picking that up soon. I also picked up a custom shift knob and transfer case shifter for Doomy's birthday. I figured this whole shebang has been a gift to her from the start, might as well continue the trend, right? hahaha. She loves them. Only thing left to do is to clean the underside of the 4runner and get it in for surgery.
In other news, i got the passenger side GTI seat installed. It sits a little high right now, but im going to go in and take about 3/4" out of the brackets and drop it down as far as the hump in the floorboard will allow me. The seat sits about 2" wider overall, so i cut the feet off the toyota seat and welded them to a piece of 1.5"flat stock i had lying around. after i got the seat centered where i wanted it, i welded some flat stock plates to the rear feet(couldnt run a bar because it would interfere with the way the bottom of the seat contours) and got the seat all burned in to where it was comfy. right now the seat does sit a little tall(seat itself is taller in the base cushion) but its got WAAAY more adjustability. Other than the fact that the seat bolsters tend to sodomize you if you dont jump far enough in the first time, theyre great! planning on doing the drivers seat as soon as the trans is finished.
and just this past saturday i decided to check the wheel bearings in the front. Doomy and I have been hearing popping and grinding from the front left for a while now and i figured the wheel bearing must be going. i grabbed the wheel(weight on the ground still) and shook it and heard a clicking. It was my daughters 9th birthday party that afternoon, so i had to wait until Sunday to get started. well, i got everything ready, jack the truck up, and give the wheel another shake in all directions. no noise in the vertical movement, just in the horizontal. and thats when i noticed that the joint on the pitman arm was thrashed. it was allowing close to 3/4" of play in the steering! The pitman arm was the one part of the steering that we hadnt replaced yet due to it breaking 2 of our pitman pullers. So some thinking between us and my dad and i decided that it would be better to cut a line in the arm with a cutoff wheel and chisel the arm loose from the steering shaft. Worked like a charm. got everything bolted up, torqued down, and regreased and the truck is back to being nice and tight again. Now we just need to replace the tie rod adjusting sleeves(one seized while they were trying to align it) and we should be good to go until the long travel goes in.
As usual here's the pics
Moving the trans to the shop.
Parts from Marlin.
Dad throwing down some quick beads.
Getting ready to weld the fron crossbar support in.
Passenger side seat in! super comfy.
Pitman arm failed. so we went to work cutting it off with a cutoff wheel.
Knicked the box, but it should be just fine.
after hitting the cut with a chisel and a sledge, it finally cracked the arm and it fell right off.
New pitman installed and all greased up.
Old Sep 28, 2021 | 06:44 PM
  #788
space-junk's Avatar
Forgot to add a pic of the shifters we got for doomy!
Old Sep 29, 2021 | 05:30 PM
  #789
habanero's Avatar
Nice match to her speaker box (iirc) and interior stuffs.
Old Oct 2, 2021 | 06:06 PM
  #790
Nice job! I just order rear bearing kits from MC.
Old Oct 8, 2021 | 11:48 AM
  #791
space-junk's Avatar
axles or transmission?
Old Oct 8, 2021 | 04:33 PM
  #792
Oh oops! Rear axle bearings
Old Oct 9, 2021 | 09:54 AM
  #793
dropzone's Avatar
Fossilized
Nice work on the seats, it will be nice to have the new transmission in. New arm should help with handling.
do you know what is leaking up front? Engine or Diff?
And how do you like Texas so far?
Old Oct 11, 2021 | 07:57 AM
  #794
space-junk's Avatar
Seat is super comfy once youre in it. Looking forward to having the trans in as well. kinda sick of the auto. and, yes, the arm has fixed all the wandering issues we had. The leak up front is from the timing cover. i need to pull it off and reseal it, but i dont have a whole lot of motivation to do that because its such a pain in the ass.
we dont live in texas yet. we are renting the house out. our date to move in is august 1st 2022.
Old Oct 11, 2021 | 01:13 PM
  #795
2022....? Geeebeezus
Old Oct 15, 2021 | 11:34 AM
  #796
space-junk's Avatar
yep. we are leasing the property for a year.
Old Oct 15, 2021 | 12:09 PM
  #797
Word...
Old Oct 17, 2021 | 03:38 PM
  #798
I am so excited for this!!!!
Old Oct 17, 2021 | 04:34 PM
  #799
space-junk's Avatar
Old Oct 17, 2021 | 04:59 PM
  #800
800!!!! Congrats! Use the "contact us" link below to see what you've won!!!!
