Cali '86 RTE 4Runner rebuild...
Old Feb 9, 2018 | 02:02 PM
  #141
Co_94_PU's Avatar
You are gonna want to read up on this swap. There are a ˟˟˟˟load of splices, details in threads here.
Ps, unless they changed it that wire is smaller than the OEM one.
Old Feb 9, 2018 | 05:09 PM
  #142
TrailTrek2Fish's Avatar
I think you forgot to include the link.
Old Feb 17, 2018 | 10:32 PM
  #143
Old Feb 18, 2018 | 10:55 AM
  #144
84 yota dude's Avatar
Oh baby that looks amazing!
Are you keeping the auto trans?
Old Feb 18, 2018 | 11:01 AM
  #145
space-junk's Avatar
I don't recall of you said you were using the stock turbo or not, but I know that smog will fail you for that manifold because of no O.E. number. If you're using an aftermarket turbo, you gotta go to the ref. Ask me how I know.....
Old Feb 18, 2018 | 08:03 PM
  #146
cdd408's Avatar
did they pass you with the aftermarket turbo
Old Feb 18, 2018 | 08:13 PM
  #147
He said he's moving to Texas! No smog anymore
Old Feb 18, 2018 | 09:02 PM
  #148
RAD4Runner's Avatar
Daymn! That's a beautiful engine!
Old Feb 18, 2018 | 10:09 PM
  #149
Co_94_PU's Avatar
X2
I passed a car on the way into work today and the color scheme of that engine stand jumped to mind as awesome for my hatchback as a rally car, now I know why..
Old Feb 18, 2018 | 10:28 PM
  #150
Thanks 84_yota_dude! You know, I've been on the fence about doing a manual trans swap. If I do, I'll do it when I get to TX. Which brings me to the next reply...
What's up space-junk & cdd408, I hope all is well. I purchased the GT25R Kit from LCE & yes, like 84_yota_dude said, I'm moving to TX pretty soon so I (thankfully) won't have to deal with the CA smog technicalities like C.A.R.B. #'s and BS like that.
Thanks Co_94_PU, it would be an awesome color scheme for a rally car!
Old Feb 19, 2018 | 05:34 AM
  #151
YOUNGIAM's Avatar
I lived in houston, tx for 5 years and had to do the smog thing yearly there. I can't say what the rest of texas is like but houston sucked.....
Old Feb 19, 2018 | 05:37 AM
  #152
cdd408's Avatar
love that valve cover, did you do the same to the intake manifolds
Old Feb 19, 2018 | 07:44 AM
  #153
Whats up YOUNGIAM, apparently my 4Runner will be exempt from a smog check because she's 31 years old. Don't get me wrong, I'm not deleting the EGR & catalytic convertor or anything of that nature. I just took this screen shot from the TX DMV website...
I sure did, cdd408! The oil pan too.
Old Feb 19, 2018 | 08:40 AM
  #154
YOUNGIAM's Avatar
Good luck with your move, I for one am happy to be back to the promised land. Testing once a year was a total pain in the ass especially when you have three vehicles, it seemed like I was constantly having to bring one in.....
Old Feb 20, 2018 | 05:55 PM
  #155
swerks's Avatar
https://www.yotatech.com/forums/f115...23/#post599205 is this the type of info you were interested in
Old Feb 22, 2018 | 07:31 PM
  #156
Oh wow!!! As of 2005 (The date of the thread) only 667 22RTEC's were registered in the US?! That's f'n awesome! So would it be safe to say that less than 1000 1st Gen 4Runner 22RTE's were shipped to the US?
Old Feb 22, 2018 | 07:54 PM
  #157
Ok y'all, I need your expertise... I want to replace these two sensors on the thermostat housing. I found the Toyota P/N for the one on the right (Switch, Temperature 89428-28020) but I can't find the Toyota P/N for the one on the left! I can't even figure out what it's for,
Thermostat housing sensors
The sensor on the left: The electrical connection core rotates a bit in the metal body and the sensing tip seems to be damaged because I can feel a wire tip protruding from it.
The sensor on the right has corrosion on the sensing tip that I'm afraid to clean off because it looks like it's already worn down from years of use.
Old Feb 22, 2018 | 09:04 PM
  #158
Co_94_PU's Avatar
Left is ac cut off, right is fuel pressure up temp (switch, temperature #2)
There were two part numbers for that (#2) for awhile, related to a starting issue they reduced the activation temperature. At some point they changed the temperature on the original part number. This one is available from the dealer, coincidence I put the AC part number into Google and found an aftermarket manufacturer in japan that lists both temp settings for that #2 switch..
89428-28030 original
​​​​​​​89428-26020 tsb
Old Feb 22, 2018 | 09:09 PM
  #159
Co_94_PU's Avatar
89428-26020 tsb
We do know!
Temp switch TSB
Here is the tsb, instructions for coping with AC idle up issues inside
Old Feb 22, 2018 | 09:11 PM
  #160
I already had the P/N for the one on the right.
Good bulletin info though, I'll verify if that modification was completed by the/a previous owner.
