blakefogt's 1987 4Runner Build-Up Thread
Old Aug 11, 2011 | 03:30 PM
  #101
blakefogt's Avatar
YES I finally got logged in again
I installed the inclino finally! Big thanks to irab88 for helping me locate a bracket and even shipping it to me.
OH and I've discovered a minor exhaust leak.
Old Aug 12, 2011 | 02:06 PM
  #102
blakefogt's Avatar
yeehaw
http://www.youtube.com/watch?v=Swv_84qpDN4
Old Aug 12, 2011 | 03:35 PM
  #103
ChefYota4x4's Avatar
Sounds like my old John Deer! hehehe. Still a beauty.... Tell ya what, ...I'LL TAKE IT, ....no really, it's ok.... Drive it over and I'll take you home in mine, so you don't, you know, waste your time with it any more hahahaha.
Cool video.... I think mine is doing that at the front side of the muflfer, lol.
Old Aug 12, 2011 | 03:50 PM
  #104
blakefogt's Avatar
thats ok i love my truck... oh yea! I also installed a viper alarm I got for free. chirp chirp allll dayyy
Old Aug 12, 2011 | 04:04 PM
  #105
Dutchbelly's Avatar
Really nice truck. Could you post your paint code? I'm seriously thinking I'll paint mine that colour when the time comes.
Old Aug 12, 2011 | 04:06 PM
  #106
blakefogt's Avatar
get your own paint code! I kid but seriously I have no idea.. I gave the truck to some friends I know and said, paint it gray but just a little darker please.. I'll have to ask him when he gets back from Sturgis.
Old Aug 12, 2011 | 04:08 PM
  #107
Dutchbelly's Avatar
Thanks, would really appreciate whatever info your buddy could give me.
Old Aug 12, 2011 | 04:16 PM
  #108
Hey, ... did you do any write up on the alarm install? Door locks and all? Remote start? Yadda yadda, blah blah? hahaha.
Old Aug 12, 2011 | 04:54 PM
  #109
blakefogt's Avatar
no write up :/ I'm sorry.
It had the lock solenoids in it.. and a used car at my dealership had an older viper system installed so i yanked it out..
I can tell you where it is though.. I installed the computer..reciever deal into the left kick panel.. My dad said when he was a yota tech back in the late 80s early 90s thats where they always went... put the speaker in the engine bay.. took maybe an hour or two.. no big deal its scary looking.. but realistically power and ground for everything. This one has door locks, alarm and kill switch.
Old Aug 12, 2011 | 04:59 PM
  #110
blakefogt's Avatar
you guys should add me on facebook if you have it!
Sometimes I can't log into yotatech.. but I'm always on facebook... updates for all my vehicles go there. facebook.com/blake.fogt
Old Aug 12, 2011 | 08:37 PM
  #111
87hillbillyoter's Avatar
dude you got one of the best looking 4runners out there. very nice work
Old Aug 13, 2011 | 04:18 PM
  #112
blakefogt's Avatar
thanks boss! I hated that sound so much, I ripped the tail pipe off completely.. Little stinky but sounds good
Old Aug 13, 2011 | 08:34 PM
  #113
blakefogt's Avatar
couple issues that I need to clear up whenever I stop being lazy..
1. I see coolant leaking out the bottom of the Throttle Body.. but starting above the hose.. Does this mean the TB needs to be replaced? If so, any thoughts on dropping the 300 and getting the big bore?
2. Upon Initial Cold start up.. (not having run for 2 or so hours) If I don't give it any gas, it will start and die instantly. When if i do give it some blips from the gas pedal it sounds like it bogs down or floods.. Does that sound like the IACV to you? should I just hit up toyota and try to buy a brand new one?
Old Aug 13, 2011 | 10:11 PM
  #114
ToyoTech559's Avatar
dont know much bout the big bore but i heard its not much gain. the MAF is so much more restrictive. i would see about using a larger one from a different toyota model before doing anything else after it
imo i dont think 2 hours is enough to be considered cold start. after 2 hours with mine it doesnt even idle up as if its a cold start. i could be wrong but dont throw parts at it till you know for sure.
little stuff like what your having can take a while to figure. most just throw parts at it till its gone.
Old Aug 14, 2011 | 06:38 PM
  #115
TheYotaLife's Avatar
What happened to your bezel? its missing the pieces around the headlights
Old Aug 16, 2011 | 06:13 PM
  #116
blakefogt's Avatar
mine are chrome.. and I dont have any chrome on the truck... so until i paint them, they look fine in my garage :p
Old Aug 16, 2011 | 06:16 PM
  #117
blakefogt's Avatar
ok.. so let me know when you come up on an 82 supra and I'll do the swap.
and ignore the 2 hours, i was just throwing a number out there. I mean dead cold. like starting after work.. or when i wake up.
Old Aug 16, 2011 | 06:18 PM
  #118
MaK92-4RnR's Avatar
what color did you paint your truck? just the factory color?
Old Aug 16, 2011 | 06:22 PM
  #119
blakefogt's Avatar
the body shop was trying to match factory... So pretty close to it. Lots of sparkles :p
Old Aug 16, 2011 | 06:58 PM
  #120
I would not think the IACV has anything to do with that.... If anything, it just get's out of the way when it's caput(Meaning; It will just no longer "IDLE UP".... rather, it will just start at 750rpm and stay there).
The IACV basically bypasses the preset throttle stop plate when cold. It does this by staying open between the 2 large vacuum hoses attached to itself, front and back. That arm inside is controlled by 'coolant temp'. As the coolant is heating UP to 96*F(somewhere around there)... it slowly closes that arm/closing the gate that's allowing more "AIR" to be pulled in through to the plenum(the front big hose) through the IACV and then into the plenum, directly(via the REAR big hose). I wound up with a new one only because mine failed all the advanced tests... And basically, the 'bi-metallic arm' controlled by coolant temp had worn out(There is also a small spring inside that pulls on that gate... As there is also a small diameter hole in the gate, even once it's closed). I have some pics of this stuff in my troubleshooting thread or build thread.... SOMEWHERE, being the key word! lol.
That condition you're experiencing when cold could be many things, but doubtfully the IACV... Could be IGN related, EFI related or even Sensor related/via either the EFI loop. Even the AFM can malfunction related to Ambient Temp or other readings it's getting. Also, ...remember the AFM gate/flap, as it opens, activates the fuel pump when the key is turned over(maybe even in STA position).
How's the fuel filter?
Gotta start doing a decent Process Of Elimination, Blake. Bust out the Troubleshooting section of the FSM, homie.
