87hillbillyoter's 87 slow broke build
Old Apr 11, 2011 | 08:04 PM
  #381
Boardo's Avatar
Hey 87hillbillyoter, what set up are you running in the rear? Are you using the Rough Country 4in block or lifted springs?
Old Apr 11, 2011 | 08:39 PM
  #382
87hillbillyoter's Avatar
running the blocks. i hate em, they ride terrible. but ill be doing the chevy 63 swap soon.
anyways, i dried out the distributor and cleaned the carb and air filter, truck runs great now. but it started heating up a little today, im gonna check it out tomorrow.
Old Apr 11, 2011 | 08:47 PM
  #383
Boardo's Avatar
Right on. That's what I was thinking of doing. But we will see. Good luck on the over heating issues. I just replaced the seal on the water pump on my 22re and that fixed my leak and high temp issues
Old Apr 11, 2011 | 08:51 PM
  #384
yea thanks man, its weird just started doing it yesterday and i have a new water pump and all new belts. im 98% sure its the thermostat though
Old Apr 11, 2011 | 08:54 PM
  #385
Boardo's Avatar
Yea. Let's all pray it is. Check all the little things before you start tearing things apart
Old Apr 12, 2011 | 10:12 AM
  #386
Bojangles's Avatar
Originally Posted by chrismcdowell25
22re?
Thermostats are super super easy to replace if it's the 22re. I just did mine the other day. The hose that comes from the radiator to the block goes to a metal pipe that angles down towards the block. Undo the two bolts and the thermostat is literally right there pull the old one out and drop in the new one and bolt it back up. If it isn't a 22re I don't think it's much more complicated. Think it cost me $10 for the thermostat.
Its the same thing on the 22R.
Not hard at all.
Thermostat is like what...10 bucks?
Ive got money on the thermostat.
Old Apr 12, 2011 | 10:23 AM
  #387
irab88's Avatar
the dual-stage t-stats work great, too. they run about $30. i got one from a guy on here when mine got stuck open. it works great. heat in under 5 mins (in the winter(when my truck had a radiator(and coolant)))
Old Apr 12, 2011 | 12:06 PM
  #388
ChefYota4x4's Avatar
Wow, I watched that video and freaked out for ya for a minute......till I read the following "Ok, did this and that and it's running great..............BUT" lol..... DANGIT, ..ok, so, please, let us know asap if the Stat fixededed it, k?
Old Apr 12, 2011 | 04:29 PM
  #389
will do! thanks guys. now my battery wont hold a charge. im gonna try slow charging it tonight and if that doesnt work, i gotta get a new battery...
Old Apr 12, 2011 | 06:58 PM
  #390
Bojangles's Avatar
Bubba, im here to tell you...Get ready.
Because it always seems that when one thing goes wrong...they all go wrong.
Im going through that rightttttttt nowwwwwww.
Try and slow charge it, its one of two things...Alternator (Which i just had to replace)
Or its just an old battery.
Old Apr 12, 2011 | 07:15 PM
  #391
haha yea, you and me both!
thats the weird thing, alt is only about 6 months old, and charges the battery fine. the battery is only about a year old.
Old Apr 12, 2011 | 07:37 PM
  #392
Bojangles's Avatar
Hmmm...Yall do have some pretty bad A winters...
Do you have a warranty on the battery?
Take it to an autozone or something and they will run a diagnostics for free.
Old Apr 13, 2011 | 06:56 AM
  #393
mightymouse's Avatar
most cases if the battery will not charge after going mudding it will be the alternator (ask me how i know).
Old Apr 13, 2011 | 07:07 AM
  #394
xxxtreme22r's Avatar
X2 this is why I carry a spare. Well I got a half a spare as of right now, because it needs to be "rebuilt". Probably just the brushes. But it's an OEM one and the one on my truck is an AZ one in which I have gone through 2 already. Not AZ fault though, but I do like my mud.
Old Apr 13, 2011 | 08:12 AM
  #395
well im assuming its the battery because if the battery is completely dead i can jump it, run it for a while, and then shut it off and i will be able to start it for a while after i shut it off. i slow charged it last night and cleaned the terminals this morning ill see if its dead after i get outta here
Old Apr 13, 2011 | 10:40 AM
  #396
Hey Bud!
Keep in mind...... AZ, etc., have been known to sell bad alternators..... and as Aaron asked, "ASK ME HOW I KNOW?!" hahaha. I went through 3 in one truck, then the 4th ran for 100K w/out issues. Even in this truck, that Kragen one took a dump in 5 months and the Napa/OEM parts one is working great. IT BETTER STAY THAT WAY, ...otherwise, it's time for the GM Alt. like Ian! hahaha.
Old Apr 14, 2011 | 07:23 AM
  #397
4runFreak's Avatar
I have always had bad luck with AZ alternators. There expensive but you ought to look into a Optima RedTop. best battery i have found so far. i got one in the shop thats 6 years old and his holds a solid charge
Old Apr 14, 2011 | 08:42 AM
  #398
it was actually a napa alt. we dont have an AZ round these parts, lol. but, i cleaned my engine bay for a couple hours yesterday with some WD-40 and a paintbrush and a rag (saw it on here somewhere and it works!) and i cleaned the terminals up and the alternator real good, and my truck sat all night and started this morning so i think my battery is fine! well see how long it lasts though haha
Old Apr 14, 2011 | 01:40 PM
  #399
Good to hear, ....but MAN, I hate those glitches almost as bad(the kind that disappear, ......right before I go on a 800mile trip! hahahaha). Still good to hear the DD is MOBILE!
Howzit been, HB? Snow melting quickly?
Old Apr 14, 2011 | 08:10 PM
  #400
haha i know exactly what you mean! im glad its mobile too! its melting quickly when its warm, lol. it was about 12 degrees this morning and i forgot i left my e-brake on last night and had to drive with a frozen on e-brake this morning haha. but it is melting pretty quick! im lovin it
