86bedlesstoy's 1986 4Runner Build-Up Thread
All good. Everything is buttoned up tonight. Only took a total of maybe 6 hours on the whole job. That ˟˟˟˟ was heavy with the intake. Had to stop and wait for my brother to get off work lend a hand.
Back together now. No leaks! BUT.. I was having a problem with having no power at all. Wouldn't rev above 1,000 rpms under any load!. Started to look at the timing. Bought a timing light as well. THEN the connector on plug #1 pulled of the boot and ripped off the wire. So now I need to buy a set of wires! GRRR. Still not driving after 3 months.. Getting tired of looking at it. Anybody have a step by step for timing this sucker?!
#31
Finally found the straight answer for timing. Have a couple of days off coming up. Set to 12 degrees BTDC. Install distributor. With rotor straight up. Jump TE-1 and E-1. then adjust to 5 degrees BTDC.
#35
Running good. Has more power than the last time I check it out. Idle around 900-1,000. Didn't see a drop in idle speed when I jumped the T-E connectors.. Hmm
#37
Serious leak. Can't see well enough to find where it is really leaking. Looks like back of head though. SHIIIIT.. New engine from 22reperformance.com would be nice.
#38
There is a cover to head coolant passage on the back of the head. 5 bolts. I have seen the bolts loose or evem missing. I would check that before you overthink it lol. If anything is loose take it off clean it and RTV that sucker and bolt 'er back on.
