7m's swapped & sas' d 87 extended cab
Old Mar 4, 2012 | 07:17 PM
  #221
7m4x4dude's Avatar
I think i bought to much.shock. i bought 14 inch stroke shocks
Old Mar 9, 2012 | 05:48 PM
  #222
7m4x4dude's Avatar
Maybe i didn't. Any how got the chevy springs installed as well as adding more leafs to my front packa and im no longer sitting on the bump stops and gives me almost 22in compressed shock length and right about 30 extended.
Old Mar 11, 2012 | 05:52 PM
  #223
7m4x4dude's Avatar
Took it on a test drive today heard some clunking inbetween shifts and after looking looks like the ubolts might not be tight enough
Well time to do emissions and tag it again
Old Mar 15, 2012 | 08:40 AM
  #224
7m4x4dude's Avatar
Passed emissions again!
Old Mar 21, 2012 | 09:00 AM
  #225
7m4x4dude's Avatar
Got the front drive line put together and i clearenced my cadinal joint still need to measure the max angle. just measured and max angle is 40* where the zert isn't hitting and where it does hit it's at 35* doing to put a plug in so i dont have to come across the day the zert breaks off in the shaft.
But here it is while its getting balenced and straightened.
Old Mar 21, 2012 | 10:16 AM
  #226
bigtrucknwheels's Avatar
looking good 7m dude
Old Mar 21, 2012 | 07:20 PM
  #227
7m4x4dude's Avatar
Drilling the front flange sucked but it is done i had other flanges around with the correct bolt pattern and in 23, 27 spline. I just could not find my socket to remove the flange nut. So i clamped one of the flanges face to face, center punched my holes and used about seven drill bits to get to the bolt size i needed. By the 4th drill bit i was aware two wholes were off center but the last two bits and the use of the flange as a patteren also worked as a guide for the drill. I do say i wish all my drill bit's were sharp as the first few new ones i had..
Thanks for the compliment. BIgtrucknwheels
Old Mar 21, 2012 | 07:47 PM
  #228
7m4x4dude's Avatar
Forgot to mention. I got the new long splin slip from trail gear and the front yoke flange was a very tight fit to the front diff flange i had to pull it it togerher with the bolts in a criss cross fashion.
Old Mar 23, 2012 | 05:57 PM
  #229
7m4x4dude's Avatar
Ugh i found three broken dowel pins in my wheel hubs, i managed to drill the center of one with two of my smallest drill bits. But after that it dulled every bit i tried.
Old Mar 25, 2012 | 01:32 PM
  #230
7m4x4dude's Avatar
Got most of the exhaust finished using scrape pipe i had laying around
Old Mar 25, 2012 | 04:46 PM
  #231
82wingnut's Avatar
shnazzy build man, how you liking the 7m swap? and from what i hear isn't it harder to find replacement and/or upgrade parts for it?
Old Mar 25, 2012 | 06:20 PM
  #232
7m4x4dude's Avatar
I like it, ive been a supra fanatic for eight years now and have owned and parted sevral so for me parts were on hand or free.
Old Mar 25, 2012 | 07:10 PM
  #233
streetlancer's Avatar
Awesome build man!
Originally Posted by 7m4x4dude
^That solid axle looks soooooo goood!!
Old Mar 25, 2012 | 08:52 PM
  #234
7m4x4dude's Avatar
Thanks street lancer. I agree.i definitely. Prefer the straight axle look alzo for how much better they wheel & off road.
Old Mar 26, 2012 | 02:34 PM
  #235
7m4x4dude's Avatar
Finished up the exhaust for now. Well till i replace the stock muffler and tail pipe.
Also noticed today that the previous owner gutted the cat .... i had no idea and have passed emissions twice now...
All i can say is dam the old carbed 22r was a dirty little engine...
Old Apr 7, 2012 | 05:35 PM
  #236
7m4x4dude's Avatar
Woodys4x4. Counter sunk. The wholes for me so now they accept the toyota cone washers and on top of that i installed a metal locking nut.
I finished one side today will have to finish the other side monday or tuesday.
Old Apr 8, 2012 | 08:48 AM
  #237
7m4x4dude's Avatar
Old Sep 30, 2012 | 08:53 AM
  #238
7m4x4dude's Avatar
http://m1191.photobucket.com/albumvi...jpg.html?o=185
I know its a link. Im trying to get the origonal so i can post it up. Its of my truck on the rti ramp and the pistonswild 4x4. Cruise in at woodys 4x4.
My rti score was 263. Hope next year improves!
Old Nov 3, 2012 | 09:05 AM
  #239
7m4x4dude's Avatar
It's been a while since I've posted here but since I have I've bought a new house with my wife so we no longer have to work in the rain. here's a picture of my truck sitting in our shop.
Its 960 square feet right now I have four vehicles in it plus room for extra stuff.
Here is a picture of my truck on a are rti ramp at the pistons wild cruisin
And last but not least I brought home a chemical cabinet from work the other day and when I opened it up and Doug through it I found this
It is a tilt meter voltmeter and oil pressure gauge combination out of 84ish Montero
Old Nov 3, 2012 | 06:54 PM
  #240
7m4x4dude's Avatar
Installed and working!
