1991 Toyota
Old Jul 21, 2015 | 07:23 AM
Gevo's Avatar
Originally Posted by millball
Looks to me like that oil might well be coming from higher up on the engine.
Look to the valve covers and rear cam plugs.
Yah, this seems to be a common frustrating source of oil leaks. Only place on the mine where there is a leak. I figured I'll live with it until there is another reason to get into the engine that far.
Either that or a magic wand
Old Jul 21, 2015 | 08:46 AM
Janos01's Avatar
Originally Posted by Robojd1
What would you guys in the forums recommend for shocks/struts(whichever) as i still have the originals installed and they are shot. Also any other exterior things i should do, looking for good spotlights/offroad lights aswell as a bullbar or roll cage to mount them on. Please add input as to any upgrades
Originally Posted by dropzone
3.0 V6 are known for head gasket issues, might wanna check your compression and take the VIN to the dealer to see if the recall was done
150k'ish is about when they like to pop
Any input on squeking, or shocks that will be used more on country roads. ALSO what was the recall on and know any good bull bars or what size bolts i need for my skid plate. Thanks
I want to do a complete engine tune up , fix the problems, add nice shocks, new seat covers and steering wheel cover, add a push bar if i can find a good on(mount spot lights and light bar) just want to keep the engine in good shape, it will idle at like 3-500 and go up and down and then die and i dont know how to fix that and sometime it just doesnt sound right.
If you are just doing city/highway driving, I would recommend KYB shocks from OReilly's. As dropzone mentioned, our trucks have and are known for head gasket issues near cylinder 6 where it blows from. As long as you do not have water in your oil, filling up your coolant often or have white smoke coming from your tail pipe, then you should not have a HG issue.
A good set of headers will also help prolong or eliminate the HG issue for good. My HG blew on me back in January and I had to REBUILD my whole engine as a result.
Lastly regarding the erratic idle, it could be either bad/dirty injectors, a vacuum leak, dirty throttle body or a bad throttle sensor.
Old Jul 21, 2015 | 10:08 AM
D.B.T. 87 4x4's Avatar
Check your vacuum hoses there's an assload of them on there, any one if them could have a hole or something and Itll make it do that
Old Jul 21, 2015 | 01:43 PM
Robojd1's Avatar
Thanks for the input i will have to check that out. Do you guys know of a nice push bar that will mount on this truck. I can get one custom made but i dont know where to mount it
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
nick b
Jul 11, 2015 04:38 AM
zd92655
Jul 5, 2015 04:25 PM
