1986yota4x4's 1986 Pickup Build-Up Thread
#449
do not "upgrade" the fuse. the fuse is there to protect the wiring. if you add a bigger fuse, you could end up with a serious problem. the components that use that 80 amps will not draw more than that, so there is no need for a bigger fuse!!!
if you add something like a winch and lights directly to the battery/alternator, then you use the appropriate sized fuse (ex- 10 amp lights, put in a 15 amp fuse, 180 amp winch, 200 amp fuse, etc)
#453
just watchin' out for the fellow yotas. i used to think that the fuse was in there to protect the device, but in school i learned that it's the wires that need protecting. if the wire is meant to handle 90 amperes max, and there's a 100 ampere fuse in there, the wire will burn up before the fuse blows. no bueno
(also, this comes from personal experience
#454
#455
Here ya go, man....(I know how it is to need something and then have to wait 24 or more hours, lol....)>>>
https://www.yotatech.com/forums/f199...l#post51668315
Hahaha... Page 64 of 187 or something, lol. Should have everything you need on there and thereafter? Take care, man!
#456
PS> Never did post my video to Youtube... will have to be tomorrow or something. It explains how to pull and replace the gearbox, which one to get, what type of fluid, how to FLUSH and bleed(VERY in depth process to all of it, but not too difficult... Just need to follow the instructions, ya know?)
#458
Great thinkin my new alternator is bad, no power coming off the post on the alt when the hot wire coming from the battery is disconnected. Getting really tires of this, it charged fine Friday night
#459
Nice I just bought my first yota it a 86 22r 4wd with 33s body in great shape it runs but has a oil leak on the timing cover I think. It came with a 94 trans in it not to crazy bout that and a good bit is Jerry rigged but I payed 1,000 for it,2 extra doors, a 15" kicker competition sub, 2amps, a ken wood cd player and an extra 86 trans Really anxious to start fixing all the rig up crap but don't know how to work on yotas
