1986 yota ect
Old Nov 21, 2012 | 08:27 AM
1986YODA's Avatar
1986 yota ect
Where is the factory ect switch on the 86 4runner. Might be something I'm over looking but I'm not seeing it on my wiring diagram. I want to rewire my 97 runner console I put in my truck to use the 97 runners ect switch.
Old Nov 21, 2012 | 03:44 PM
MudHippy's Avatar
86 might not have one. I can't find it in the 85 FSM. But I can find it in the 88 FSM and the 88 WD. It's called the Pattern Select Switch in those. So maybe you just weren't looking for the right thing.
Anyway, if you can find the ECT ECU, then you can follow the wires for the switch all the way to it(in theory).
Good luck!
Old Nov 23, 2012 | 02:25 PM
MudHippy's Avatar
Follow up: I just found evidence stating that 86 4Runners with a 4 speed ECT(Electronically Controlled Transmission) do have a Pattern Select Switch.
Where it is? You tell me...
Old Nov 23, 2012 | 02:30 PM
1986YODA's Avatar
I believe I found the plug... Just have to figure out the wiring... And how I'm gonna hook up the etc switch from my 97 4runner console to work it
Old Nov 23, 2012 | 02:36 PM
MudHippy's Avatar
That's good. Turns out I spoke a little too soon. Since I went and looked around a bit more after posting, and immediately found a diagram showing where it is/should be. Which might confirm where you think it is(or not).
PNC 84720
JonG85
Jan 18, 2023 04:31 PM
Ditch Doc
Oct 27, 2015 03:20 PM
dirk89
Oct 1, 2015 05:15 PM
shredder4286
Oct 1, 2015 01:09 PM
Cycles
Sep 29, 2015 06:37 AM
