Thoughts on performance
Old Sep 16, 2020 | 09:00 PM
Sho671's Avatar
I'm doing some real basic bolt ons on my 84 Runner 22R (carb) and I was hoping to open a convo on Intake, exhaust, cam, clutch upgrades. I already bought my LCE intake kit with emissions delete (Weber 38). I'm now looking into headers. I'm not trying to spend 400 on LCEs manifold, but it seems like they are superior to Doug T, Hedman, Hooker, and Pacesetter. On the cam, I always heard comp, crane, and Isky are the winners here. Anyone use Redline or LCEs regrind? Clutch I think I'm Centerforce stage 2 just bcus I have used them before and was satisfied. What do you guys think?
Old Sep 16, 2020 | 10:33 PM
OldBlueMidnight's Avatar
5 Year Member
The half inch flange on LCE's header is key if you're running an air injection system since this superheats the header, probably less important if you're eliminating air injection, or didn't have it to start with. I was told to avoid tri-y headers and stick with a four-into-one, and have been happy with the LCE header for years. I'm using LCE's torquer cam, seems fine, not a game changer, but it was one of many upgrades intended to boost torque and that definitely happened. With the carb change and other upgrades you're doing, I'd spend some time making sure you're in a good zone with your air-fuel ratio. Probably less of a problem with the 38, but I was running lean for a few months after I got my 32/36 hooked up and now I have a valve recession issue I will have to deal with eventually. That's my two cents, basically your plan seems like a good way to go, although you'll probably get 80% of your gains from the header and opening up the rest of the exhaust, 10% from emissions delete, and 10% from intake and carb. On the other hand, most stock carbs and emissions stuff is so decrepit at this point it needs to be replaced / removed.
Old Sep 21, 2020 | 10:41 AM
Sho671's Avatar
Thanks for the input
mark_cantrill42077
Nov 14, 2020 09:31 AM
Tugger01
Jul 19, 2011 04:44 AM
87redyota
Jul 17, 2011 01:34 PM
jinotown
Dec 17, 2010 06:54 AM
live4soccer7
Aug 31, 2010 11:50 AM
