Supercharged 1985 Toyota Pickup Trail Rig Build
Old 02-23-2019, 06:34 PM
  #81
yellowtoytruck's Avatar
I upgraded my tires and rims
Old 02-23-2019, 09:15 PM
  #82
SheepishLion89's Avatar
How are those on the highway? Noise wise.
Old 02-24-2019, 04:58 AM
  #83
I am actually very surprised at how quite they are. And the ride is incredibly smooth. I am very happy with my purchase.
Old 02-24-2019, 04:24 PM
  #84
T
Took the truck out on the Apache Trail outside of Phoenix. Rode great. Road noise is very quite.
Old 03-07-2019, 10:07 AM
  #85
I bought myself a fun new shovel
Old 03-08-2019, 03:42 PM
  #86
coryc85's Avatar
Sick shovel, I can't tell if that is a tool or a weapon. Either way I like it.
Old 03-08-2019, 06:46 PM
  #87
jakey poo's Avatar
why can’t it be both
Old 03-10-2019, 09:32 PM
  #88
Ran the wiring for my rear Harrop E-Locker today. I still have to install my relay bank and run control wiring to my switches. I take my time to do any wiring be it small or large projects. I took the wiring that came with the locker, put expandable sleeving over that, and then wire loom over that. Before running it I checked continuity to make sure that the connector was made up correct and it passed. I wanted the locker wire to be secure and less prone to damage so I ran it up and along the E-Brake. I was able to feed it through the frame channel in front of the gas tank bringing it over to the left side of the truck. From there it runs up the panels under the drivers seat up the the brake booster area. Sorry the pictures aren’t the best
Old 03-10-2019, 09:35 PM
  #89
I also installed my URD Rear 02 Simultor. I ordered it months ago but finally got around to plugging it in. It is attached to the rear O2 sensor and I have the module mounted in the trays that run from from under the driver
Old 03-18-2019, 02:16 PM
  #90
Got around to mounting my aux fuse box and relay panel. I decided to use some existing theaded holes and make a mounting plate. Pretty simple.
Old 04-15-2019, 03:03 AM
  #91
Wiring progress
I got more wiring done for my switch panel. I still have more to do. The weather pack connector you see contains all the wires that activate relays in my relay panel plus one fused wire for my USB port on the panel. The rolled up wiring consists of wires for led backlighting, power to activate the relays, and grounds.
Ill finish that wiring when I get the wires fed through the firewall. My locker switches will have a safety switch on my gauge pillar so i don’t activate my lockers at high speed
Old 06-16-2019, 07:51 AM
  #92
After two months of extremely long hours at work I am finally able to work on my truck again. First thing I did was add my new bean bag cooler and foot vent from a first gen 4Runner. This was super easy to do.
Old 06-17-2019, 01:14 PM
  #93
So I finally ran all my wires for my busman relay box. I ran a new hole through the firewall. All my relay wires are going through this hole.
This is my Locker safety switch. So nobody engages them while going down the highway
Old 06-17-2019, 01:16 PM
  #94
Video of my switch setup
Old 06-18-2019, 09:53 AM
  #95
Discombobulated's Avatar
Excellent work!!!!
Old 06-24-2019, 10:30 AM
  #96
Lono&theGremlin's Avatar
Thumbs up
Very slick man. I was looking to do the same Bussman relay setup. Doesn't matter now cuz it looks like you did a great job, but for others there's a good write-up on Tacoma world: https://www.tacomaworld.com/threads/...-block.399454/
Question - where'd you get the switch panel? or did you source the switches individually? Also, did you have to trim or clearance the dash plastic at all to make it fit?
Old 06-25-2019, 04:28 PM
  #97
Hey thanks for the link. I actually saw that link before. I did the cost break down and minimum order of some of the components for the switch build up and time it would take to build it and I just decided it be cheaper for me to buy from somebody. The panel I got was very well done. I can’t complain.
I got the switch panel from Paranoid Fabrication. It’s for a 2nd gen Tacoma. I had to do a little cutting of the bracket to fit my dash supports but I didn’t modify the dash at all or the trim piece.
I got all the switches off the link on paranoid fabrications website. Except for the USB charger which I got from Waytek. I believe i posted the links earlier in this thread.
Old 06-30-2019, 03:02 PM
  #98
The next round of parts for the next upgrade are in.
I am going to do a Rear-Up-Front swap. Old man emu rear springs up front, bilstien shocks, new shock hoops, cross-over steering, IFS steering box, U-bolt flip kit, boomerang shackles,
Old 06-30-2019, 03:25 PM
  #99
Did a quick upgrade the interior. I’ve seen lots of people use these LED kits so I decided to give it a try. I also have the set for the gauge cluster but haven’t installed it.
Before
After
Old 07-04-2019, 01:02 AM
  #100
Talking
Dang no way man you're beatin me to all the mods haha. I'm in an 85 as well (wish I could say it was supercharged too though) and I'm also looking to do the high steer conversion, hoops, hanger, longer springs yada yada after I finish this cab swap. I literally have those boomerang shackles in hand too haha. But anyway, I can't remember if you're already running the Old Man Emu suspension but the rear springs are pretty dang stiff. I'm on their 2" lift heavy load spring rate right now and it's not a very forgiving ride unless I'm really loaded up and aired down. I don't doubt you've thought it all through and I guess you've got the heavier engine up front which would compensate but just figured I'd give you a heads up the OME rears pretty stiff.
But yeah, kudos to you man, that should be a fun mod regardless. Really dig your work so far, its been a really fun thread to follow lately. Good luck and keep it coming. Keep an eye out for my cab swap build thread coming soon. Aloha
Quick Reply: Supercharged 1985 Toyota Pickup Trail Rig Build
