LIVES4CRAWLIN91's 1985 4Runner Build-Up Thread
Old 06-04-2010, 05:40 AM
  #81
RajinCajun's Avatar
Hey Crawlin, I see you are here too. Imagine that Will be posting pics of my 85 Build over in the build up section.
Mike
Old 06-04-2010, 03:57 PM
  #82
LIVES4CRAWLIN91's Avatar
Originally Posted by 89silverpu
haha no way! You'd wanna go with the chromo output shafts and 23 splines at least in the rear though...that's a lot of torque on that little output...not to mention that you have to buy two adapter plates $$$$$$$$ lol
Love your 4runner! Man it was pretty when you first bought it lol
ya two adapter plates and chromo shafts with a 30 spline final output and keeping them all 2.28 and im just touching what a brand new ultimate dual case cost. and ya she was pretty but u know how it goes. smash something in and then fix it so it doesnt happen again lol and i loved the idea of as half dove instead of a full dove...
Old 06-04-2010, 03:58 PM
  #83
Mike
YO mike wats up man... Hows the 85 comin? and has the new family member arrived yet lol?
and assumin u forgot the names Spencer btw lol... When is the next BCOR meeting?
Old 06-06-2010, 09:50 AM
  #84
grant526's Avatar
Originally Posted by LIVES4CRAWLIN91
I FINALLY GOT THE CORRECT TOP SHIFT CASE IN TODAY, so ill finish my front axle this weekend swap out my rear and drop the tranny install the marlin clutch and put the "new" transfer case in and then ill be saving again for the crawl box kit tear my old case down make a crawl box out of it and then time to finish the suspension... although what about triple cases? have a 2.28x 2.28x2.28 slightly lower than a 2.28x4.7 lol or maybe go super crazy and put a double 2.28s and a 4.7 transfer lol thats like 5.2X4.7=24.4 reduction.... AM I CRAZY for considerin 3 cases?
If you go dual 4.7s and a stock 2.28, you'll have the same triple setup as Marlin. When he factors in his 5.29s in his axles and the super low 5.15 of his imported diesel transmission he's running 1372:1 overall reduction. lol If you run that same setup with a stock G52 or G54 trans, you'll be at 1046:1. . . Or the dual stock boxes with a 4.7, 4.88s (I think that's what you said you're running) and stock trans, you'll be at 468:1.
To continue my rant for one more second, if Marlin installed a 3rd 4.7 set instead of the stock box, he'd be at 2828:1. . .
End Rant
Congrats on the getting the Top shift box. I'm going to convert mine when I install the crawl box. . .
Keep us posted with the install of the new box! Good Luck with it!
Old 06-06-2010, 10:33 AM
  #85
I've actually got ther 5.29s ... anyways finished stripping my front axle down and when this is all done ill have pics of what was destroyed anyhow, foun out short side birf was toast, not toast as in completly destroyed, but u will see, will be dropping the tranny tonight, and i think im going to go dual stock cases, when i get around to it, and btw i have two gear drive forward shift cases if u know of anyone looking
Old 06-07-2010, 10:34 AM
  #86
grant526's Avatar
If you had a second top shift, I would be wantin' to trade you. But I've got two forward shift units.
If I talk to anyone thats lookin, I'll point them in your direction.
Looking forward to the pics. I just rebuilt my rear diff, but didn't get any pics.
Old 06-07-2010, 05:17 PM
  #87
got some pics boys oh and i just dropped another 230 bucks.... ordered an axle truss. diff armor and knuckle ball gussets and better than stock birfs... for now. didnt get the tranny dropped... my front axle is main priority ya know. cuz i have become a pro at droppin the tranny and dont think much of doin that, and the rearend swap will happen once ive got the front back in.. ANYWAYS here are a few pics
Old 06-07-2010, 05:28 PM
  #88
bracketry cut off and ground down and cleaned up some welding splatter...
I cannot wait to get my drop hanger and build a spring pack or order some tgs... sad my shocks have way more droop than my springs lol
cleaned up knuckles
my "custom" back plates
scuffed up birf from blown lower trunion bearing
see my crack.... glad i caught this now... instead of after rebuilding everything
Old 06-12-2010, 08:19 AM
  #89
PismoJoe's Avatar
Lookin good...when can we see the finished product!!!!???
Old 06-12-2010, 10:15 AM
  #90
I'm waiting on some armor to roll in and my better than stock birfs, but I will def post pics, considering I'll be relearning to weld on the armor so ya . wish me luck
Old 06-12-2010, 10:17 AM
  #91
I do have a question... What front kit should i go with. TG 3s or TG 4s? either pack may get a rear main swapped in to give me the added length of a ruf so i have a much better shackle angle and all that. IDK opinions greatly appreciated or and my goal tire size is 37-38s with a 25-27 inch frame heighth. soya input greatly appreciated
Old 06-13-2010, 09:22 AM
  #92
PismoJoe's Avatar
Dirty 30's er what???
Old 06-14-2010, 06:26 PM
  #93
na. I wish i could spring for dirty 30s, but then again I have beat the livin piss out of my stock birfs and considers 2 blown wheel seals. 1blown lower trunion bearing and a cracked birf. not bad. so for now im staying 27 splined but trail gears chromo version.
Old 06-14-2010, 06:31 PM
  #94
PismoJoe's Avatar
Good choice, can't go wrong with moly
Old 07-01-2010, 11:54 AM
  #95
PismoJoe's Avatar
LIVES, whats goin on over here? You're movin slower than I am lol any updates???
Old 07-05-2010, 10:18 AM
  #96
grant526's Avatar
I'm running a SuperLift HD 4" lift with seriously sagged fronts, but 2" shackles to level it. At the middle of the Drivers door, I have 24" to the frame, with 35" tires. You'd have to do some serious trimming of the front fenders and possibly tub the firewall to run 37s or 38s. Though you can move the axle further forward to allow better clearance. I've moved mine 1.5" forward so far and the 35s rub a little at full lock. But I also have to mention that's with a welded rear diff, so the body roll in slow turns is SUPER Exaggerated!! lol Especially on pavement and hard surfaces.
Old 07-09-2010, 04:35 PM
  #97
Ya sorry I havent been on here the 4runner is back together and running decently still need to finish up the exhaust, as soon as it clears up ill get pics considering my camera went nill in the midst of all this junk
I do love the wider rear end and 1.5 spacers up front it actually helped the COG a ton
Old 07-09-2010, 04:39 PM
  #98
Thats my frame heighth, and i havent moved my front axle forward any,but use to rub horribly when stuffed at full lock... the 1.5 spacers actually helped, and as soon as the weather clears up and i can get my rear suspension done, ill be orderin a hanger kit and hysteer and all those goodies and doin an ruf setup using the projunk springs and rears together and if that doesn work then ill probably spring fora set of sky man springs or tg springs which if i go with tgs ill be swappin a rear main in but im plannin on movin the front axle 3" forward and then tubbin considering i have these really cool view holes in my firewall lol
Old 12-01-2010, 12:32 PM
  #99
Hey guys sorry that its been ages since i last posted. I still havent gotten the my lift finished lol and ya but i did get alot of other stuff on the way to getting finished. here come so much need toy porn lol
beginnings of softop frame
finally got around to tubbin it in lol
finished soft top frame in rustoleum gloss black haha
Old 12-01-2010, 12:33 PM
  #100
ill have to take some more pics as soon as i get it back I dropped it off today at an upholestry shop to get the soft top sewn up and all that i just hope it comes out right
Quick Reply: LIVES4CRAWLIN91's 1985 4Runner Build-Up Thread
