high compression 22r
Old May 29, 2013 | 06:52 PM
djhaulsballs's Avatar
Finally starting the rebuild on my 85 22r. After 240xxx miles it finally decided to give way. The lower coolant hose blew causing it to overheat and warp the head.
The head is currently in the machine shop gettin flattened out as well as bigger valves and rv spring kit from engnbldr are being installed. Going to order some high compression Keith Black pistons, the street performer cam from LC, as well as the dual timing chain kit from them.
Old Jun 3, 2013 | 05:26 PM
RisinRebel's Avatar
What's your truck setup?
Old Jun 4, 2013 | 10:47 AM
Pretty much stock. has stock gears with 31s, 3in lift, and a mini spool in the rear. I plan on gettin a bigger lift with hy steer, 35in tires and 5.29 gears. also i plan on bobbing the box after i take the besides off and run tubing with an exo cage.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
dumpster84
Apr 30, 2016 06:03 AM
RatOmeter
Oct 22, 2015 03:17 PM
thefishguy77
Jul 30, 2015 10:59 AM
calderp
Jul 27, 2015 09:58 AM
