Fink's 1985 4Runner Build-Up Thread "Ratchet"
Old 09-18-2009, 06:11 PM
  #161
Lumpy's Avatar
Originally Posted by 4x4Fink
He said the only other thing he would try is completely disconnecting the rear LSPV - he said in theory that would allow the maximum amount of braking pressure to the rear.
In turn, that may help reduce the severity of the passenger side pull.
I'm sure you can remove the bracket that mounts to the axle but then it needs tied up. If you just remove the bar all together the rear wheels won't do a thing. It needs to be in the upward most position for the rear to work harder. If you remove it all together you'll need to do a lot of splicing and T's in there.
I'm not saying it can't be done I don't think it will solve your issue. It may, I have not had one of those apart and I don't recall how many lines com out of it. I think it's 1 in 2 out...if it's 3 out it very well could be your issue.
1 to the rear then a splitter on the axle. Is there 1 going to the front and a T or does it have 2 going to the front?
Old 09-19-2009, 01:41 PM
  #162
Fink's Avatar
Originally Posted by ocdropzone
Fink: I just woke up (night shift sucks) but I don't recall seeing ball joints on an SA Toyota....might consider another Tech
Yeah, I don't think he meant ball joints.
I'm going to get under it this afternoon (if it stops raining) and measure it myself to either the bottom bolt of the knuckle or to the tire to at least get an idea of how off it is.
I know how night shift goes, I just woke up myself not too long ago.
Right, I would just unbolt it from the bracket and zip tie it up as high as it will go to the frame somewhere.
Should be interesting to see how it goes.
Thanks for the input, I will check to see how many lines go where and such.
Fink
Old 09-19-2009, 03:55 PM
  #163
Fink's Avatar
I undid the LSPV bracket and tied it up to the exhaust bracket.
I didn't notice much of a difference.
I did lock the back tires up though, so they're working fine.
I did some practice stopping at abount 45mph and as long as I keep the wheel turned to the left about 90* I can stop straight.
But if I get caught off guard I'm hitting the curb - I really don't think I'll flip or roll, but I will definitely hit whatever is next to me.
I'm thinking about taking it to a different body shop and telling them the problem I am having and have them just start over - not tell them that it's already been jig'd once.
Can't hurt anything really, if they say it's still crooked then I'll take the printout they give me and go back to the other body shop and chew 'em out and see if I can get a refund or something.
Fink
Old 09-19-2009, 11:42 PM
  #164
colsoncj's Avatar
have you traced out the front brake lines?
Old 09-20-2009, 04:33 AM
  #165
Lumpy's Avatar
I really don't think it's the frame...It's gotta be something in the front brakes. Are there 2 lines coming out of the LSPV and going to the front or just one going to the front?
Old 10-10-2009, 01:59 PM
  #166
Justinvd's Avatar
Havnt been on yt for a while, but the 4runner is looking good fink.
Old 10-10-2009, 04:03 PM
  #167
JeEVeS's Avatar
He did mention a bracket that he used to put on his dirt track cars that allows you to adjust the angle of the axle without having to cut and re-weld the hangers.
He tried to explain it to me but I probably wouldn't do it justice explaining it on here - I'll try and find it on Google and post it up.
Fink
Im sorry if i am not close with this cause i just dropped in to the post.
maybe something like this for minimal adjustment. we use them in the bimmer world for suspension changes
http://store.bimmerworld.com/shared/...t=products.asp
Old 10-28-2009, 10:20 AM
  #168
Fink's Avatar
I haven't had a chance to trace them yet - I have been slammed with work and school.
Haven't even been on here in almost a month!
I'm going to try and find some time in the next week or so to get under there and trace the lines.
A buddy recommended one of the guys at Advance Auto where we get the patrol cars at the PD worked on so I may take it up there and see what he thinks.
It has to be something in the brakes.
I think I am also going to take it and get an alignment - I haven't had one done since I've owned it and maybe that will reveal some underlying issues.
I'm also thinking of selling the 35's and putting some 37's on it but that won't happen until I can get the pull squared away.
Fink
Old 10-28-2009, 02:08 PM
  #169
turboturd8607's Avatar
Holy Horny!!!! nice truck
Old 10-28-2009, 07:02 PM
  #170
ADH8796's Avatar
Fink
I agree on the 37's after you put the new springs on the 35's are looking little.
Old 10-28-2009, 09:14 PM
  #171
VLP
VLP's Avatar
Don't know if this has been asked yet, but what kind of truck bed liner was used on the entire truck? Looking into my options. Awesome 4runner by the way!
Old 10-29-2009, 02:18 PM
  #172
Wheelingnoob's Avatar
I would highly recommend an alignment, also look at all the TRE's and lose the J arm steering ASAP.
Good luck and cool looking 4runner.
Old 11-29-2009, 07:23 PM
  #173
Fossilized
Staff
dropzone's Avatar
well any luck?
Old 07-02-2010, 11:43 AM
  #174
Fink's Avatar
Just realized I never updated this thread.
I ended up selling it - my buddy Dave buys older cars, restores them and then sells them.
He's already done a TON of work on it, his mechanical knowledge is way beyond mine so this is perfect for him.
I am waiting for him to email me some pictures of it to see what all he's done - I'll post them up here when I get them.
Thanks for all the help you guys gave on this, I was able to do a lot to it...that darn pull was still there until the day I sold it though...
Fink
Old 07-02-2010, 12:25 PM
  #175
Outsane's Avatar
Buy it back when he is done
Old 07-22-2010, 08:46 AM
  #176
mfresh513's Avatar
nice rig, looks super similiar to the one im about to purchase but mine has a spool in the rear, what do you think is better?
Old 07-22-2010, 10:38 AM
  #177
colsoncj's Avatar
spool vs. what?
Old 04-08-2013, 02:46 PM
  #178
locked4runner's Avatar
very nice!
Old 04-09-2013, 04:52 AM
  #179
Gizler00's Avatar
Just started reading through your thread. Very nice runner. I like the bedliner exterior.
Old 04-27-2013, 11:52 PM
  #180
'85 Yota's Avatar
Sad you sold it! My 85 pickup pulls to the right sometimes. You got me interested in getting OME leafs and cutting my fenders to fit tires. I love the look.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jon.r
07-11-2015 03:34 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Fink's 1985 4Runner Build-Up Thread "Ratchet"
