Z's 80 SR5 build
Old Jan 26, 2014 | 07:52 AM
Gizler00's Avatar
Great looking truck!! And what a great trade also!! Cant wait to see more of this build.
Old Mar 19, 2014 | 09:49 AM
Z's Confederate Toy's Avatar
Thanks man! I can't wait to get it done.
Just waiting on parts right now. I ordered a 23 spline input gear for the 4.7 case from Marlin. Also having them update my V6 adapter for the gear drive case. Shouldn't be waiting much longer now
Old Apr 3, 2014 | 08:32 PM
Finally!! A real update although not really much of one. I finally got it moved into the shop to pull the engine. Feels good to have some progress on this beasty again.
And out
Finally out and clear to make room for the 3.4
Now to what I wanted to show y'all... This is my guess as to why this terd never ran from the get go.
Someone decided that after they cracked the block that MIG welding it was the best way to fix it. They missed a crack though, clearly visible above the bird poop welds.
Size:  820.1 KBName:  WP_000904_zps73fae983.jpg
I haven't torn it down yet but I am curious to see what is on the inside.
Old Apr 4, 2014 | 04:13 AM
83 trail rig's Avatar
Wow we painted our pickups the exact same ha
Old Apr 4, 2014 | 05:55 PM
  #25
slacker's Avatar
wow .. makes me shake my head
people with welders , who shouldn't have welders !!
Old Apr 4, 2014 | 06:06 PM
  #26
Originally Posted by Z's Confederate Toy
We have everything for a hybrid setup already. Going to put some money into it bulid a killer motor. Stroked and bored, forged everything, o/s valves, cam, EFI. The works. Just need something to put it in.
almost 5 gs in my motor there is a place little known for forged pistons and h beams name brand almost half the price of the other guys
Old Apr 8, 2014 | 09:42 PM
  #27
Agreed! That is a fix that I wouldn't have even considered.
Dang! That is alot. But worth it in the end I would imagine?
Old Apr 9, 2014 | 03:07 AM
  #28
Agreed! That is a fix that I wouldn't have even considered. Dang! That is alot. But worth it in the end I would imagine?
it started as a head gasket then I got a little carried away
Old Apr 9, 2014 | 03:52 AM
  #29
dropzone's Avatar
Fossilized
Looks like you are slacking on your antler collection
Are the early Bronco grills also results of hunting trips?
Old Apr 9, 2014 | 05:22 AM
  #30
Loved my 69 bronco I was living on kauai and my mango tree broke in a storm and the bronco was flat 302 3 on the tree
Old Apr 9, 2014 | 06:34 AM
  #31
Lol most of those are the old man's from over the last 30 years. And the EB grills are also the old man's. He's a fanatic.... He has 7 of em...
They're great rigs. I grew up in the passenger seat of dads 73. That's where I picked up all my wheelin experience.
The one in the pic with the antlers use to be mine.
Old Apr 23, 2014 | 09:11 AM
  #32
Small update. Nothing much, stuff kinda moves slow around here with so much other things going on. (1 Bronco project, like 8 Toyota projects between 5 of us, and 3 Escorts to maintain...) But I have my small pile of parts. The 2wd rear sump pan and pick up, the updated Marlin V6 adapter, dropzone's old twin stick kit. I decided to not powdercoat the conversion mounts because I can't get the pos HF coater to work properly for me... It's dumb. So a couple of coats of rattle can flat black will have to suffice for now.
I did finally get the engine and trans pulled out of the 4Runner. I need to now put the oil pan on, move the oil dipstick, and pull the crossover exhaust. I think I will end up running both banks right out the back for ease and cheapness.
New pan and pickup
Engine out.
Old Apr 24, 2014 | 07:48 AM
  #33
dropzone's Avatar
Fossilized
If you can do the 3.4 with out a BL that would be cool..
Now get to work my friend..
Old Apr 24, 2014 | 08:18 AM
  #34
That is what I am shooting for. I REALLY don't want to run a body lift.
I am trying to get some work done but my old man seems to come up with something for me to do every time I go out to the shop to work on it... I think he's jealous
Old Apr 24, 2014 | 05:20 PM
  #35
slacker's Avatar
I used a 1" body lift on my Trekker , only because I didn't want to cut the hood ..
Old Apr 24, 2014 | 05:31 PM
  #36
can we maybe come up with some mounts and crossmember that would allow the swap
I'll check on some things this weekend at my wheeling buds
Old Apr 24, 2014 | 08:37 PM
  #37
That will be legit. I am using Chikat's conversion mounts. Not sure if they allow the engine swap to be with out cutting the hood or body lift. I will find out soon enough though. I am hoping to have it dropped in Monday since I have the day off.
Old Apr 25, 2014 | 04:01 AM
  #38
Nice let us know what you come up with I would like to know for the future builds
Old Apr 27, 2014 | 10:22 PM
  #39
Will do. Should have a good idea of how I am going to do it by next weekend.
Old May 3, 2014 | 07:20 PM
  #40
I was finally able to get quite a bit of work done on this thing today
Took the 3.4 R150 tail shaft housing off
Replaced it with a 3.0 R150 tail shaft housing to accommodate my early Marlin V6 adapter
The adapter RTVd on and bolted in
The Chilkat conversion mounts on
Frame side
I relocated the oil dipstick tube to the proper spot. I just used the factory tube instead of looking for a T100 tube. Just as easy, only needed to drill out the hole to half inch to make it fit. No pic...
The 2wd rear sump pick up and pan installed.
