Where to get leaf spring mounting plate / leaf spring seat?
The seat/mounting plate for the leaf spring u-bolts on a '75 Pickup are rusting out, anyone know where I can get replacements? Not seeing them on any of the usual spots. This is the plate that goes under the axle and leaf springs which you bolt the u-bolts thru, with integrated shock mount... Someone must make them, right? Anyone know what years and models they're interchangeable with? Don't seem much different on my '75 than on my 2000 Tacoma...
I am not sure what other models (if any) work for your truck. I have not personally worked on a 1975 Toyota.... yet!
Unless someone here knows you might be able to get used parts off of newer Toyotas and see if they physically would work.
Finding parts for 1970s and earlier Toyotas is pretty hard most of the time.
Good luck!
toyospearo
Aug 8, 2010 12:35 PM
