Toyota Fiberglass: 1983 Trekker Build-Up Thread
EDIT : with new INDEX
page 1 - start of frame build
page 2 - front diff build
page 3 - engine mock up
page 4 - front drv shaft , engine exhaust crossover pipe , tranny/transfer crossmember , rear disc brake mock up
page 5 - shock hoops , emergency brake mock up , front track bar , rear traction shocks , emergency cable build
page 6 - fuel sender build , Frame POR-15
page 7 - frame assembly , starter
Page 8 - wiring harness start , brake lines & fuel lines
page 9 - original Trekker tear down
page 10 - cab rust
page 11 - rocker repair
page 12 - shaved drip rails , battery tray remove , smoothie cowl
page 13 - cab repair and EPOXY primer , first full body mock up
page 14 - floor and tranny tunnel build
page 15 - first wiring harness mock up
page 16 - steering mods , battery trey , engine bay mods
page 17 - brake lines
page 18 - supercharger & FIRST start .. VID
page 19 - light works vid
page 20 - wiring
page 21 - floor install and front seat mock up , front cooling fan
page 22 - body computer box , tires , engine computer , antenna , dash build
page 23 - antenna , dash , fuel sender
page 24 - my GOLD metal
page 25 - supercharger installed and running VID
page 26 - dash mock up
page 27 - center console build
page 28 - door skins
page 29 - door skin install , new hinge pins
page 30 - cup holder , center console guages , first dash assembled pic's
page 31 - rear seat mock up
page 32 - box skin repair , tub rebuild , tub floor build
page 33 - rear tub frame build and roll bar mock up , seat hinge mock up
page 34 - rear hatch , kick panels , custom Valance
page 35 - front bumper , fiberglass door panels
page 36 - door panels , wiper motor , final tub modifications
page 37 - wire harness sauder
page 38 - cab prep for paint
page 39 - trim prep
page 40 - COLOR
page 41 - cab install , sound deadner
page 42 - wire harness install and loom , dash re- assembly , heater box clean and install
page 43 - tub PERMINENT install , rear sound deadener
page 44 - sterio wiring
page 45 - sub box build
page 46 - finally some carpet
page 47 - Body panel install and rear bumper build
page 48 - It runs , you tube vid + rear canpoy build starts
page 49 - Blocking out the old roof , and sneek peak @ interior seat fabric
page 50 - NEW fiberglass roof mould and front headliner start
page 51 - NEW fiberglass roof
page 52 - headliners
page 53 - off to paint
page 54 - outside and together , seat fabric and stripes
page 55 - yikes , broken glass . mudflaps and exhaust tip and FIRST show and shine
page 56 - vids
page 57 - more shows and vids , supercharger oil change
page 58 - paint specs
[SIZE="5"]Sorry , cant do hyperlinks , so you just have to find the page [/SIZE]
bought a few Trekkers a while back .. and now have started my own .
this one is going to be a "some what" stock restoration .. but with a few "extras" .
so here's where I'm starting .
don't mind the dust .. it's been sitting inside my shop for a while now .
there is one small rust hole on The right side .. front spring hanger , inside box steel .. you can see it in the pic .. it's so minor , I'm just going to weld in a patch .
so a little work today ... got onto the frame repair .
got the little plates/patches welded in .. It really wasnt that bad at all , the main / worse dammage was from me hitting with a hammer it trying to find the rust .. I really didnt see any point in doing "fish plates" .. as there (in my opinion) was NO structural strength loss . Other side is perfect .
and done ..
also started "prepping" the frame for the POR-15 treatment.
page 10 - cab rust
page 20 - wiring
page 39 - trim prep
page 40 - COLOR
page 56 - vids
and done ..
Good to see you doing something for yourself instead of building one and shipping it elsewhere. I'm sure it will be a NICE build and the extras worth the trouble. What is POR-15 by the way?
thanks guys ..
yep .. por-15 is a coating .. prevents O2 from contacting the steel .
stops rust , and seals the metal . http://www.por15.com/
I have used it before . and it's great stuff.
so , now that the "LONG box" Trekker is gone , I can now start building mine ..
I bought a "parts truck" a while back .. for a couple of reasons .. I needed a long box frame for the dimentions of the long box Trekker .. I needed a front clip .. I needed lots of small parts and pieces for my trekker build , so I bought a whole truck .
so Yesterday .. I started to tear it apart .
box had been removed previously , and I had cut a hole in the back of the cab for the "long box Trekker" I built ...
Now that that project is all done (for me anyway) It was time to get to work on my project .
I sold the long box frame .. and I need alot of the pieces for my trekker .. so time to strip it .
lots of work yesterday , cut the roof off , and rockers , and cab corners .. I'm going to make some replacements so i wanted to keep them . got the engine bay mostly stripped , and engine out .
and here is where I started this morning ..
and finally the cab off ..
frame stripped ..
and diffs ready to build .
and finally my front clip .
frame stripped ..
My wife saw me looking at your post and said,"No way are you taking your truck down that far!"
Gonna be a nice job from the ground up.. Is that 2nd Gen front clip for your hot rod project?
Bumper brackets are yours when you want them...will get a shipping price for you next week...and can send them when ever you need'em
front clip is for my Trekker .. it was punched on the front right side .. bent the frame and dammaged the inner wheel house I wanted to keep that cab , because it has the OE moon roof .. so I will repace the front clip .
Thanks , freight quote would be great ..
so the supercharger is GONE .. he sold it out from under me ! ohh well , I wasnt overly excited about it anyways , I was pretty leary about buying it .
so .. I'm thinkin' maybe 3.4L and supercharge it , or maybe V8 .. kinda like the idea of staying toyota .. any ideas , anyone know of any 3.4 installs into 79-83 vintage ?
Im pretty sure ORS has done it before, check out their website or shoot them a pm/email. I really like the idea of the 3.4, go for it.
EDIT: *subscribing*
