Rollz79 79 long box build
Old Feb 28, 2012 | 05:18 PM
Dustydriver007's Avatar
The new Weber carb looks great. Did you have any problems putting it on. I heard sometimes they leak. What adapter plate did you go with?
Old Feb 28, 2012 | 06:30 PM
Rollz79's Avatar
I didn't run into any problems installing the carb. The only reason the have leaks is because of the adapter they come with from Redline. I have the 2 peace adapter. I hate it I change the gasket every 4 months. i am going to get LCE adapter this summer.
Old Oct 23, 2012 | 02:44 PM
Rollz79's Avatar
Its been a while sense i have updated my post. Done a few things to the truck.
Got some 2" wheels spacers
With spacers on
Last April we have a few events called mud of the farm. Some of you local guys know what i am speaking of. Well needs less to say the motor didn't last threw that weekend. The motor started to knock. Well only way to get the home to was to drive it. Well I almost made it.
Here how she sat for a few months
The truck sat for a few months. I got another 20R for free. Drove the truck for a few days with the new used motor in and my lucky would have it that one started knocking.
Old Oct 23, 2012 | 03:24 PM
Rollz79's Avatar
I am building a engine as we speak. So far I have
81 22R block .020 over bore
Rods have been media blasted with new wrist pin bushings
Crank been polished
All slandered size King bearings
ARP rod bolts
ENB 20R over sized valves
Oregon Re grind RV3 cam 290 lift
79 20R head shaved .030
LCE Oil pressure bypass valve
Oil cooler
Timing chain set
Still need to get
LCE ADJ cam gear
LCE dual valve springs
LCE crank scraper
ARP head studs
OE Toyota oil filter
OE Toyota thermostat
Gasket set
22R rocker arms
Right now I can't really do much to the motor. I broke my back last month at work fell 15 feet off a roof. So i can do anything right now. Just buy parts.
I will post pics of the parts i have so far later.
Old Oct 23, 2012 | 04:40 PM
  #25
Lons81's Avatar
Great work so far, hope you heal quickly with no lasting problem. Keeping an eye on your build for future ideas
Old Oct 23, 2012 | 07:00 PM
  #26
Rollz79's Avatar
Here are the pics i promised.
I got bord the other day i decided to go ahead and change the springs inside my dizzy.
Still trying to decided if i will keep the vac advance.
Old Oct 23, 2012 | 07:47 PM
  #27
UPS's Avatar
UPS
Broke a few vertebra myself some years ago. After a few months you find ways to do things that seem too hard at first.
Old Nov 25, 2012 | 06:36 PM
  #28
Rollz79's Avatar
Haven't done much lately. I got around to porting the oil ports on the timing cover.
Old Dec 27, 2012 | 06:28 PM
  #29
Rollz79's Avatar
Got around to painting my block.
Old Dec 27, 2012 | 07:18 PM
  #30
NickMiller's Avatar
The paint on the block looks awesome! Sub'd!
Old Jan 6, 2013 | 01:03 PM
  #31
Rollz79's Avatar
Picked this up they other day for FREE
Went to the junk yard to find a few parts for my civic and found this. A dough thorely tri y header for $20.00
A little WD40 and a 2 hours of my weekend.
Old Jan 6, 2013 | 03:01 PM
  #32
NickMiller's Avatar
$20 + a bit of elbow grease is a great price for that header! Nice score!
Old Jan 22, 2013 | 06:17 PM
  #33
Rollz79's Avatar
Fresh rebuilt Holley 350 cfm Moded for blow thru set up.
Found a lot of good info on here.
http://www.hangar18fabrication.com/blowthru.html
Upgraded light sockets for the coner marker lights. These cam from a pre 88 crx.
Old Jan 27, 2013 | 02:19 PM
  #34
Rollz79's Avatar
Not much of a update. I've painted. a few parts.
I also got a few of my other parts on for mock up.
Godspeed vacuum block
Boost Ref Fuel Pressure Reg
OIL Catch Can
Got my gauges mounted up
CB radio installed
Finished installing my front grill
Old Mar 14, 2013 | 05:05 PM
  #35
Rollz79's Avatar
Small update fixed my fuel line. I went ahead and ran new metal line.
Starting to put my engine togather. ARP rod bolt went in.
ARP headstuds on top
And parts that came in today.
Old Mar 18, 2013 | 08:09 AM
  #36
dirtdobberoffroad's Avatar
what are the wheels off of on the truck in the first picture with the bed on the truck....stock taco's?
Old Apr 4, 2013 | 07:08 PM
  #37
Rollz79's Avatar
They are off a mid 2000's chevy/GMC
Old Apr 4, 2013 | 07:11 PM
  #38
Rollz79's Avatar
No real big update. My turbo I will be using. Came of a 7m supra.
Old Apr 7, 2013 | 12:27 PM
  #39
Rollz79's Avatar
Small update the engine is about ready to drop in
Arp's installed with LC Cam Gear
Now for the head
ENB oversized 20R valves
LC Dual valve springs and chromaly retainers
How its sits now
Old Apr 7, 2013 | 02:45 PM
  #40
tditoyota's Avatar
Looking good
