My 1980 RN47 build
Old Feb 24, 2017 | 06:49 PM
  #41
flg8r22's Avatar
@Old87, if your an Aisin carb guru, let me know. I've got several I'd like to have rebuilt.
Old Feb 24, 2017 | 08:42 PM
  #42
old87yota's Avatar
No, not even close! Sorry.
All I know about them is from the Factory Service Manual, a few YouTube videos and threads here.
I have been having some performance issues and figured that it couldn't hurt to rebuild the carb. 30 Years is a pretty good life for a carburetor that has never been rebuilt!
I will post how I do everything when I find the time if you are interested. By that time, I should have a pretty good idea of how they work.
I probably get around to it mid to late March.
Old Feb 25, 2017 | 06:22 AM
  #43
Terrys87's Avatar
Not sure how I missed this build. Truck is in far better shape then what you find around here. I like seeing you doing the Pontiac. I like any in depth build. Looks like you have it tore down quite a bit. I will be looking forward to how your builds go.
Old Feb 25, 2017 | 07:19 AM
  #44
flg8r22's Avatar
Thanks Terry. I just read thru your tips and tricks thread for the fourth time last night. I always see something I overlooked.
Old Feb 25, 2017 | 02:49 PM
  #45
flg8r22's Avatar
Built and painted these today in just a few hours. The millennials love this stuff.
Old Feb 27, 2017 | 05:47 PM
  #46
flg8r22's Avatar
So today I had a spare minute and pulled the bed on my own. It's resting nicely on a little tilt trailer I have until I'm ready to do metal work on it. Here's a few pics of the half nekked 4x4. I didn't realize how small these trucks really are compared to the F-250. The brake line inside the rail was brittle. I'm glad the po used this as a farm rig and not for the street.
I think when the clay is scraped off there may only be some light rust.
I think I may run a flat bed while I'm doing the metal work on the bed.
The cross members are surprisingly in relatively good shape. I won't have to use the spares I have.
This is what was left of the failed brake line. It rusted so badly it was the diameter of a pencil lead.
Old Feb 27, 2017 | 07:48 PM
  #47
Terrys87's Avatar
Frame looks great. I do not see any rust thru it. I think it will clean up nicely. A small trailer is real handy for working on beds.
Old Feb 27, 2017 | 07:55 PM
  #48
flg8r22's Avatar
Thanks Terry. It's sounds funny to say it but I think the clay protected it somehow. I try to keep a jet ski trailer around for stuff like this but I'm sold out. The little tilt that could will have to do
Old Feb 28, 2017 | 02:22 PM
  #49
flg8r22's Avatar
Pretty boring update today. I've pulled the brake lines and now begin the task of making new ones. Napa is my only local retailer to have the Japanese metric brake line Union as I am using a two piece to go from the right front frame rail to VSP. Have to wait three day for the union to come in. Maybe tomorrow I will do the front and rear springs.
Old Feb 28, 2017 | 02:46 PM
  #50
flg8r22's Avatar
The original springs have definitely given up the ghost
Old Feb 28, 2017 | 07:31 PM
  #51
Terrys87's Avatar
I helped to restore an 82 and we got some factory replacement springs from a local mom and pop shop. I liked how that truck rode. I had some Old Man Emu on my 85 and they rode harsh. In my opinion OME would be great for rock crawling but not for a daily driver. Also the OME if I am correct give a 3 inch lift. I was eventually going to go with stock springs on the 85 but never got around to it.
Old Mar 1, 2017 | 05:43 AM
  #52
flg8r22's Avatar
Morning Terry. Hope y'all weren't effected by the tornados yesterday. We used to have two real good spring shops here that had less than a day turnaround. Now the closest I have is a hundred miles away. If the pro comps don't work out I will get a set of originals done there.
Old Mar 1, 2017 | 06:04 AM
  #53
Lons81's Avatar
I used Nicopp Japanese brake lines when I plumbed my brake and clutch lines. You don't need a bending tool as it can be bent by hand and doesn't kink. Check my build thread
Old Mar 1, 2017 | 06:33 AM
  #54
flg8r22's Avatar
Thanks Lon. I looked at a roll of that yesterday. Do you know if it has a tendency to bulge? I'd really like to go stainless but it's way out of budget. The ease of the Nicopp installation definitely makes it an attractive option.
P.S. I live on your build thread. Excellent work and thanks for the aftermarket a/c info.
Old Mar 1, 2017 | 07:16 AM
  #55
Lons81's Avatar
I don't have first hand info about any bulging. It was recommended by my hot rod friends who use it all the time. The lines I used were AGS CNJ-360 Japanese lines from CarQuest. I bought the 5' sticks and had only 2 or so connectors to lengthen. They have the right size fittings for Toyota, inverted flares
Old Mar 1, 2017 | 01:06 PM
  #56
flg8r22's Avatar
Finished mocking up the brakes today. I found a couple sticks of brake lines at two different Napa's and a coupler. Test drove and brakes are strong. I will need to adjust the rears just à bit. I'm pretty sure I will go with the Nicorr lines if I decide to recon the entire truck. I got to bend one up at the auto parts store and it seems really good. Test drive showed me I need to adjust the carb and check the timing. Maybe tomorrow as I need to adjust the valves as well and change all the fluids before I take it on a short trip.
Old Mar 1, 2017 | 01:09 PM
  #57
flg8r22's Avatar
An old clothesline reel was my weapon of choice for bending the brake lines. Worked perfectly!
Old Mar 2, 2017 | 11:11 AM
  #58
flg8r22's Avatar
This is exactly what I wanted to see today! Nice factory paint
Old Mar 2, 2017 | 12:19 PM
  #59
flg8r22's Avatar
Old Mar 3, 2017 | 07:10 PM
  #60
flg8r22's Avatar
The truck is running like crap today. When I get to higher rpms (2200+) it just sputters, so I couldn't drive it to the car wash to pressure clean the frame. It idles fine and will Rev in neutral but under a load it just falls on its face. My wife helped me chisel and hose some clay off the frame. Tomorrow I'll take the flap disc to it to clean it up for some por15. I'll post some pics tomorrow
