baileysyoda 83 build
Old Sep 5, 2013 | 09:47 AM
baileysyoda's Avatar
Originally Posted by -Yoda-
What did you do with the camper top??
Truck looks great btw! Would look awesome with some wider rims and 33x12.50s.
the camper top is on the side of the house for now. ill probably only use it on camping trips as my sleeping area haha. i wanted 33s but there would be rubbing due to the fact that i dont have a bigger lift lol...and i still need decent gas mileage out of this until i get a daily driver!
Old Sep 5, 2013 | 09:54 AM
yotantn's Avatar
I'm a wing nut.. I got my threads ran together and thought you were talking to me. Lol. I just recently put my camper back on and I need bigger tires too.
Sorry.
Old Sep 5, 2013 | 04:25 PM
-Yoda-'s Avatar
I have a 3 inch rough country lift and run 33's. My rims have a big offset and a really deep dish though so I don't have any rubbing issues. It can be done. I can measure it if you want?
What kind of mileage are you getting right now?
Old Sep 5, 2013 | 04:41 PM
-Yoda-'s Avatar
Here is a picture of what they look like. This was sitting flat stopped in a waterhole....the tires stick out about 3 inches from the fender
Old Sep 20, 2013 | 09:31 AM
  #25
taking it for its first real wheeling trip today!! pics should come up tonight! i am extremely excited!!
Old Aug 3, 2014 | 07:55 AM
  #26
haven't updated the thread in a long time, but I have a problem, last night driving home I took a corner, accelerated, then all of the sudden my engine started making a god awful sound, and missing pretty bad, rpms dropped at idle, only makes the knocking noise (sounds more like a violent tacktack kind of noise) when in gear going down the road, I dont know if the timing chain and guides have been replaced, has about 170xxx miles on it, i need to figure out the problem and soon, its my daily driver and i need to be able to get to work
Old Aug 3, 2014 | 07:56 AM
  #27
should probably mention it has a 22r
Old Aug 3, 2014 | 01:13 PM
  #28
gillesdetrail's Avatar
Well remove the valve cover check for anything abnormal or metal deposits, do an oil change and cut the filter open to check for debris, if you have bad signs then time to pull out the engine!
Old Aug 3, 2014 | 01:58 PM
  #29
RobotMoose's Avatar
It sounds to me like it's the timing chain, but the chatter should really only be apparent when starting cold. I have would recommend giving it a thorough listen to see where the sound comes from in the engine, because t-chain chatter will be relegated to the front of the engine.
I also agree that you should pull the valve cover and look for any problems.
Old Aug 3, 2014 | 09:57 PM
  #30
so I pulled the valve cover, didnt see anything out of place, i also changed the oil, no metal shavings and no milkshake color. took it to the dealership my dads friend works at. they called, after not doing any real tests (compression, leak-down, etc) and they have said i have a miss (no ˟˟˟˟) not firing on one maybe two cylinders, asked if i want to pay 1800 for them to pull the head and look. hell no. i could rebuild it for that much...going in tomorrow to talk to the service manager to have them finish the tests. really hoping its a timing issue. if not...what would be a sensible rebuild kit to buy? Id like something that could give it a tiny bit of pep, but not full blown race truck stuff lol
Old Aug 4, 2014 | 04:20 AM
  #31
RobotMoose's Avatar
Often a jumped t-chain will just seem like a miss. When mine jumped, I'd spent hours trying to chase down imaginary vac leaks and fiddling with the carb. Turns out it was much worse than I'd thought.
Enginbldr offers pretty much the best bang-for-the-buck rebuild kit you can lay hands on. He can do anything from mild to wild and takes the time to talk you through everything you have in mind to help you get a good picture of what to do.
Old Aug 5, 2014 | 09:37 AM
  #32
83 trail rig's Avatar
20 years of shop exp says timing chain
Old Aug 8, 2014 | 11:16 AM
  #33
so i have a blown head gasket, severly blown, more things wrong long story short the toyota dealership messed up bad, getting an engine swap done from them for 2300. anyone know of LKQ engineering?
Old Sep 16, 2014 | 08:46 AM
  #34
havent updated this in a while...but its alive!! finally have my baby back! this has opened my eyes and I now realize I should probably get another truck...not selling this one though...this will be my daily driver..gonna get another truck to be my toy, oh and i added an air line fitting from my on board air kit...ill take a pic of the hose hooked up later
Attached Thumbnails baileysyoda 83 build-bay-truck-2.jpg   baileysyoda 83 build-bay-truck.jpg
Old Sep 18, 2014 | 12:58 PM
  #35
Here's some pictures of my cb setup, and my Low Range Off-road shifter knob
Attached Thumbnails baileysyoda 83 build-image-69495996.jpg   baileysyoda 83 build-image-671983750.jpg
Old Sep 18, 2014 | 01:00 PM
  #36
And of course my train horn and air tank haha
Old Sep 18, 2014 | 01:05 PM
  #37
83yotadream's Avatar
Dude sweet ride and love the train horns! wish I could find a set around here for cheap!
Old Sep 18, 2014 | 01:53 PM
  #38
Thanks man! And amazon! Mine were surprisingly inexpensive
Old Sep 18, 2014 | 02:31 PM
  #39
Here's some pictures I've found of it out on different adventures, last ones of it and a makeshift sled we towed behind it
Attached Thumbnails baileysyoda 83 build-image-2740245338.jpg   baileysyoda 83 build-image-4014633169.jpg   baileysyoda 83 build-image-1543713846.jpg   baileysyoda 83 build-image-3105014798.jpg   baileysyoda 83 build-image-339612234.jpg
Old Nov 8, 2014 | 04:19 PM
  #40
Here's the truck all polished up. I just love the way first gens look!
