1983 Toyota Pickup.
Old 05-07-2014, 01:09 PM
  #61
Erick561's Avatar
Location: I ship from New London Connecticut I PriceMatch
Foam in the frame...i know u don't intend to restore it but damn thats hack
Old 05-07-2014, 01:14 PM
  #62
Erick561's Avatar
Originally Posted by Cab4you26
Anyway, I encountered a big setback today. I originally planned on putting all new gaskets on the engine so it had no leaks when it was all back together. I pulled the valve cover today, and this is what I found:
So I'm pretty bummed about my find. I hadn't planned on rebuilding this engine. When I drove this thing home, it was ridiculous how gutless it was. I'm surprised it even got me home looking at the internals on it. And the reason I don't want to rebuild it is because I'm sure it will still be pretty gutless after a rebuild. And I originally just wanted to do gaskets to hold me over until I could locate a wrecked Tacoma with a 3rz. Not only that, but by the time I spend the money to send this thing off to the machine shop, desmog, carb, exhaust, etc. I feel like I could have spent comparible money to do a 3rz swap. So I'm not sure what to do right now.
i've pulled valve cover off (4 bolts + move throttle + accessories out of the way) of every engine/vehicle i've bought before buying it. bummer!
Old 05-07-2014, 01:19 PM
  #63
Erick561's Avatar
How long ago did you paint your frame? Looking back on it now, I wish I'd gotten the right gun to spray the inside with POR 15. I probably could have done it with my shutz gun, but I couldn't find any empty canisters at the time to put the POR 15 in. That's how slacker did his and it came out pretty nice.
I had my frame painted with Bill Hirsch Miracle Paint, Aluminum based
Didn't top coat it, it still looks the same 4 years later!
Old 05-07-2014, 02:29 PM
  #64
Cab4you26's Avatar
I didn't put foam on the frame. The previous owner did. That's also inside the scrap frame. The new frame is coated with 3m rust fighter on the inside.
Old 05-08-2014, 05:38 AM
  #65
Cab4you26's Avatar
The past couple days I have finished my knuckles, removed bearing races (Any tips for installing the new races into the axle?), went to the junkyard and picked up some wheels, doors, headlight trim, and headlight buckets.
Por15, primer, and painted knuckles:
Junkyard finds:
And I started working on the spare doors:
I also finished up another project: Lifting my engine stand. Now it's ready to play in the rocks!
That's it for now. I still need to clean up my locking hubs, blast and paint the wheel hubs, get new wheel studs, vented rotors, v6 calipers, and then I should be ready to put it all back together.
Old 05-08-2014, 05:53 AM
  #66
Erick561's Avatar
I used big sockets.
Everything looks great
Doors look awesome
Old 05-08-2014, 11:06 AM
  #67
Staff
kawazx636's Avatar
Make sure you mind you manners with the "lifted" engine stand. Once you get the weight of that engine teetering off it you may have stability issues with that pivoting single front wheel. I can see that thing flopping over quick!
Old 05-08-2014, 11:37 AM
  #68
Cab4you26's Avatar
Yeah you're right. Originally I was going to weld two casters where the stock ones went, but the wheels would hit when pulling it backwards or turning. I may end up getting some longer square stock the length of the rear and welding them up like that.
Old 05-08-2014, 02:14 PM
  #69
dog walker's Avatar
Large alluminum or brass drift. Like 1" up round stock.
Old 05-08-2014, 08:29 PM
  #70
Staff
kawazx636's Avatar
I always keep all my old bearings and races for this very reason - I've collected a whole bunch of them over the years. Brass drifts can be great, but some times it can be a pain to drive them in straight. What I do is use the old race and a mallet to drive in the new race so that it drives in straight and doesn't marr the new race. Works great and I've never had a problem doing it.
Old 05-08-2014, 08:34 PM
  #71
Staff
kawazx636's Avatar
Here's some pictures for example:
Oh, and it's also easier to turn the old race upside down when driving it in
Old 05-08-2014, 08:35 PM
  #72
HighLux's Avatar
Bearing driver set is a great investment. Just saying.
Old 05-08-2014, 08:42 PM
  #73
Staff
kawazx636's Avatar
Way to be all technicall and stuff Dave!
Old 05-09-2014, 04:16 AM
  #74
83 trail rig's Avatar
i had a race stuck on the new race had to remove them both after and ruined them both I learned to take a file to the old one so it's easier to remove after you hammer it in against the new one
Old 05-09-2014, 05:24 AM
  #75
HighLux's Avatar
Im curious about the cam failure above. Lobe is wore exactly like the one on my 87 was. Literally. My cam was on an ebay head the previous owner had bought when the engine was rebuilt. Was that head/cam stock or possible ebay one like mine was? From what I understand...the factory cams are case hardened and rarely do that. The ebay ones...sometimes are not even hardened and smoke pretty quick. Do you know?
Old 05-09-2014, 05:33 AM
  #76
Staff
Terrys87's Avatar
I have seen something quite similar to the picture you are talking about. I dont know the history of the head that I had or even looked to see if it had any factory stampings on it, but the cam was in the same shape. I curious for any more info as well.
Old 05-09-2014, 05:53 AM
  #77
Staff
kawazx636's Avatar
Oops, good point... I forgot to mention that I also put a slight chamfer on the old race so it doesn't get stuck
Old 05-09-2014, 12:23 PM
  #78
gillesdetrail's Avatar
On motors with large aftermarket cams I've seen wear like that caused by running engine oil that doesn't have enough zinc (zddp), but on that motor my guess is that it is not an original toyota cam and is not treated.
Old 05-09-2014, 02:21 PM
  #79
Cab4you26's Avatar
Thanks for the advice guys! I remember the races were a tight fit coming all the way out. So I imagine they would work pretty well if cut down a little.
As for the camshaft, I can't say if it was aftermarket or OEM. I can say it had the factory carb, and a BUNCH of vacuum lines were plugged with caps and screws. It leaked out of every seal. Not all the lobes were worn down, though. Some were just bone dry.
And change of plans, going to scoop up some IFS hubs tomorrow and an axle housing to match. The extra width will be nice, but I mostly want it for the ease of breaking the axle down. One question, though. The guy who is selling these parts said the rear axle has a pinhole in it and patched it with some two part something? He said it doesn't leak, wants $150.00 for the rear axle minus the third member. Does this sound like a good idea/fair deal? I think if I haggle him a bit I'd come out alright.
Old 05-09-2014, 03:05 PM
  #80
150$ for a rear housing is very expensive, especially if it's not in perfect shape, I paid 40$ for mine, would pay 60-80$ for an IFS rear housing, and 150-250$ for a complete rear axle.
Quick Reply: 1983 Toyota Pickup.
