Vehicles - Parting Out Parting out a vehicle, post it here
Parting out 1992 and 1993 V6 4Runners Winnipeg, MB
Old Apr 9, 2013 | 07:07 PM
99blackSE's Avatar
Located in Winnipeg, MB just north of Grand Forks.
The 1992, full load, sunroof/PDL/PM/PW/AC etc., 192,000 km (~110,000 miles). Sunroof controls, master cylinder sensor, couple of window motors gone, the rest is still there. Auto 3VZE.
The 1993, bit of a stripper, manual windows, no AC, etc. 323k but some newer parts on it or at least it looks like it (rad, etc.). Seats, passenger side rear door and panel, centre console, stereo are gone. Manual 3VZE.
Also have other 3VZE and 22RE parts still around as well (like new Enginebuilder timing kit, alt, fuel injectors, etc.).
Prices to follow as I pull the stuff off.
Some stuff from before...
Cupholder - 10
Rear Window Relay - 25
22RE fuel rail with injectors - 50
3VZE fuel rail with injectors 50
ECU - 40
Old Apr 11, 2013 | 09:31 AM
99blackSE's Avatar
Drivers side caliper, rear gate switch, rear gate lock cylinder, and rear wiper bits are gone from the '92.
Old Apr 11, 2013 | 03:04 PM
vital22re's Avatar
totally a bro
Please include location in title as per classified rules next time. Title edited. Thanks.
Old Apr 11, 2013 | 08:01 PM
Troy Lovick's Avatar
I thought it was cold in southern nevada at 50f - lol!!
I'm looking for the top end wire harness - fuse box to fuel injectors and water temp/pres sensors - reed valve and that 3 hole vsv that mounts next to the reed valve on the air intake.
my 4runner is a 95 vz-e 4wd AT - so the harness will have the knock sensor
Old Apr 14, 2013 | 07:37 AM
99blackSE's Avatar
My bad vital22re.
Yeah it's been going to down to around 0 F still some nights here, the highs are around 30. When I start tearing down the '92 (hopefully this week) I'll check this out for ya.
Old Apr 14, 2013 | 03:01 PM
aye87's Avatar
i need a fender seal/splash shield on passenger side inner (2 piece) not the plastic one but the one close to the engine, if it is in good shape let me know
my zip code 19038
Old Apr 15, 2013 | 08:32 PM
99blackSE's Avatar
my zip code 19038
Hmm I'll try and check it out tomorrow.
Old Apr 16, 2013 | 10:26 AM
blu911's Avatar
Shift Knobs Good? Rear View Mirror Good?
Old Apr 18, 2013 | 09:34 PM
99blackSE's Avatar
my zip code 19038
Are they a metal piece and then a loose almost vinyl-like piece?
Sent you a PM.
Old Apr 19, 2013 | 12:56 PM
aye87's Avatar
Sent you a PM.
they are not metal or plastic, more like vinyl
Old Apr 20, 2013 | 07:47 AM
99blackSE's Avatar
Okay I'll try and check that out later today.
Drivers caliper and O2 sensor are gone from the '92.
Old Apr 21, 2013 | 04:50 PM
abourgeois's Avatar
v6 5 speed
How much would you want for the v6 5 speed transmission? I am located in Winnipeg as well. Thanks
Old Apr 21, 2013 | 06:10 PM
99blackSE's Avatar
PM sent. aye87 and blu911 I'm still working on those pictures for ya.
Old Apr 29, 2013 | 08:45 AM
99blackSE's Avatar
Some stuff from the engine bay of the 1993...not selling this particular lower intake but the one from the 1992 should be good when I pull it.
The truck had a wonky idle so I'm not sure if it was a bad TPS or what.
Upper intake manifold - 20
Throttle body/w TPS - 20 note: I have not tested the TPS so it may be bad, TB itself is still functional
Fan clutch - 20
Evap canister - 15
Distributor - 20
Coil and igniter - 15
Interior pictures on the 1992.
Old Apr 30, 2013 | 03:25 PM
mtbradshaw's Avatar
Need a part from your 1992 4runner
Hey, I'm interested in the cap for the window lock button on the driver side door of the 92. My girlfriend vacumed ours up at the carwash years ago and I've always wanted to replace it. I'm thinking $10 plus I'll pay for the shipping
Old May 2, 2013 | 08:24 AM
tyes's Avatar
PM for the auto shifter with cut harness. shipped to 93725. if you have pic that would help.
Old May 2, 2013 | 07:48 PM
babyfood1217's Avatar
passenger headlight assembly to 98107. Thanks!
Old May 5, 2013 | 02:56 PM
99blackSE's Avatar
I'll see if I can get to that in the next few days, had to pull the transmission on the '93 for a guy so I was busying with that and school.
Will send you a PM in a day or two, have to do some scrap hauling over the next couple days.
I'll try and get you a picture or two in the next couple days of what is on there right now.
The grey '93 is gone so all I have left besides what I took a picture of above is the ECU and the gauge cluster. Everything else I left on the truck as it wasn't worth it for me to pull it the way my schedule is. I still have the whole '92 to pull apart for interior pieces and other things yet.
Old May 6, 2013 | 09:05 AM
99blackSE's Avatar
So I checked out the headlight and it had a stone chip that cracked the glass so it wasn't a good part, sorry.
Old May 8, 2013 | 06:53 AM
Thanks for checking that! GLW rest of S
