Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Things to do before starting up Datsun for first time in 3 months?
Old Dec 24, 2011 | 01:50 PM
Philbert's Avatar
Question Things to do before starting up Datsun for first time in 3 months?
Quick Q:
My Z has been sitting idle in my garage since September while I redid the dashboard. I disconnected the negative battery terminal so as to save the battery.
Everything is reinstalled and I've turned the key to ACC - all the dash lights work!
I want to get it out of the garage and pull in my truck for my transmission swap. Is there anything I should do to the Z before turning it over? Pour a little oil over the valve train, hand-turn the crank a few times? Anything else or should it be fine to just turn over with no prep?
Thanks!
Old Dec 24, 2011 | 02:03 PM
Elton's Avatar
3months thats nothing fire it up let it run tell its warm.... id check the air cleaner first make sure nothings made a home in there lol
Old Dec 24, 2011 | 02:08 PM
rworegon's Avatar
Or, tried to eat your wires under the hood.
Old Dec 24, 2011 | 02:49 PM
Philbert's Avatar
Thanks Guys.
The only thing that's been in my garage are raccoons and I'm pretty sure they don't fit into my air filter housing Will check it out before I turn the crank.
Old Dec 24, 2011 | 06:32 PM
rworegon's Avatar
Ah yes, I read your raccoon thread. They do like chewing on hoses and wires though.....they wreck havoc on farm equipment around here. Good luck!
Old Dec 24, 2011 | 10:55 PM
Philbert's Avatar
It started fine, let it idle for fifteen minutes, then a quick run round the block. Truck is now in the garage for the next project!
voiddweller
19
May 2, 2016 09:10 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
saphirekosmos
Jun 22, 2015 10:26 AM
infinityisfive
Jun 16, 2015 06:51 PM
