Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Dodge 5.2 not getting hot!
Old Dec 11, 2013 | 11:05 PM
Roark's Avatar
So, my dad has a '98 Ram 1500 4x4 with the 5.2 V8. He had the water pump changed a few years ago, plus a new thermostat with it. He said before the water pump change, the heat would burn you out of the truck.. After the water pump change, it wouldn't get NEARLY as hot. Then earlier this year, he had someone at work put in another 190 degree thermostat, thinking the heating problem was caused by a faulty thermostat. Again, the truck wouldn't warm up to what it had before.
With it getting to 15~ consistently now where he lives, the heat is a definite priority.. Today he put a 1/4 inch thick piece of plywood in front of the radiator with a few slits in it, and the thing STILL doesn't warm up properly.
The gauge says 160-180 or so at operating temp, and he says it used to run around 210-215.
Any ideas? I'm thinking thermostat, again.. But it would mean 2 faulty thermostats in a row, which just seems WAAAY too unlikely.
Old Dec 11, 2013 | 11:07 PM
Roark's Avatar
Also, the radiator is full, and the hoses are showing no signs of major leaks.
Old Dec 12, 2013 | 10:46 AM
Roark's Avatar
New day bump..
Old Jan 28, 2014 | 05:57 PM
urduadma's Avatar
The last thing I want with some work car is work to do on it. I'd stay away from 98-01 corollas unless you like wrench work.
Old Jan 28, 2014 | 06:10 PM
Discombobulated's Avatar
What?
Old Jan 28, 2014 | 06:31 PM
Roark's Avatar
Originally Posted by Discombobulated
What?
Check out his sig and maybe it'll help explain..
Hahahahaha
MichaelKLerner
Oct 27, 2015 07:18 PM
dbollier123
Sep 29, 2015 05:23 PM
Matthew Perez
Sep 28, 2015 05:43 PM
taraf
Sep 25, 2015 02:57 PM
LotOMiles
Sep 14, 2015 11:45 PM
