bleeding tips for 98 dodge dakota 3.9 clutch
Just wanted to share my method of bleeding a slave cylinder and master clutch in a dodge Dakota 98 take slave cylinder out of vehicle and also the master clutch and reservoir and put it all together just like u would in the vehicle first take piston out of slave cylinder and fill it up so that it fills the master as well at the same time keeping the resovoir full do not let it empty out at no time once your slave is full keep it all together and install it in the vehice . should have some kind of pedal good luck and hope it helps
