Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
87 Camry dies in drive, runs good in reverse
Old 06-24-2015, 07:22 PM
91toybeater's Avatar
1987 Toyota Camry wagon, 2.0 automatic. Runs good, starts fine, backs up with no problem. Put it in drive, engine dies. On jackstands, it will run in drive until you put the brakes on. I think the lockup converter is locking up before it should and causing this but I'm not 100% certain. What I'm looking for is a wiring diagram so I can isolate solenoid # 3 and see if I'm anywhere near correct.
You guys rock!
Old 07-13-2015, 08:57 PM
The problem was found and repaired.
The engine lifting hook on right side was digging into the main harness and shorted out intake air temp wire. Engine rocks backwards in forward gear and zap. Easiest repairs are sometimes the hardest to diagnose. Took an assistant dropping it into gear while I looked around under the hood.
Hope this helps somebody down the road.
You guys still rock
Old 12-27-2015, 07:46 PM
OopsMyBad's Avatar
Dude, this is one of those problems that makes you rage until you catch it, and then you laaauuuugh and laaaaauuugh... Good job. I'm a veteran professional tech and that would have driven me insane.
TNRunner88
07-01-2015 08:00 PM
sonic concepts
07-01-2015 02:33 PM
XtremeOff-Road
16
06-27-2002 07:32 PM
Quick Reply: 87 Camry dies in drive, runs good in reverse
