WTB: Rear Window Switch 88 4Runner
Old Jul 27, 2008 | 11:01 AM
4RunnerFreedom's Avatar
In need of a good rear window switch for my 1988 4Runner.
Thanks
Old Jul 27, 2008 | 11:12 AM
srozell's Avatar
Are you sure the switch is what you need? If the rear window stops working there are a number of things which could be causing the problem. Often overlooked is the absence of a rear wiper.
The switch should be the same for any Gen I or II 4Runner.
Old Jul 27, 2008 | 12:46 PM
DeathCougar's Avatar
Not quite. The switch will work 84-91. In 92, they eliminated the rear window lock button, and redesigned the rear window switch. It wont plug in.
Basically, you need to look for a clear plug (84-89) or a green plug (90-91)
If you find one with a blue plug, it will not work.
warrenjcarlson
Jul 22, 2016 11:47 AM
voiddweller
19
May 2, 2016 09:10 PM
