wtb part for 5-speed swap
Old Mar 12, 2007 | 10:54 AM
tweedersi's Avatar
toyota: 89 4runner sr5 V6
i want to swap out my auto tran out of my 89 4runner sr5 V6
i need
5-speed trany
manual tranfer case
pedal assembly
clutch master cyclinder with lines and slave cyclinder
manual ecu and engine wiring harness.
i welcome any tips on doing this and let me know if i'm missing anything.
Old Mar 12, 2007 | 05:52 PM
swamprunner1's Avatar
man i wish you would have posted this last week...I had everything you need for the swap. I just sold the tranny last week. I live in kitty hawk but get up that way often.
I have everything else you need for the swap
pedals
clutch mast cyl
line to slave cyl
slave cyl
shifters and boots
shift fork
computer but the auto one should work
don't need to swap the harness...just get rid of neutral saftey switch.
done this swap several times...pretty easy...takes a weekend
pm me if your interested in the parts. I'm headed to the airport this weekend and could meet you somewhere with the parts.
Old Mar 13, 2007 | 03:22 AM
tweedersi's Avatar
pm'ed
Old Mar 13, 2007 | 09:08 AM
toyotaman22r's Avatar
I have the pedal and clutch master cyl off of an 88 4x4. Pm me if you're interested.
Old Mar 14, 2007 | 06:42 AM
Discipher's Avatar
i have everything needed but for a 4cy and not V6 from an 87 4run
dont forget flywheel too though and maybe? diff bellhousing?
jeff
Old Mar 15, 2007 | 03:06 AM
tweedersi's Avatar
why would i need the diff bellhousing?
should the bellhouseing be part of the tranny?
also my climate control broke, so i need one bad.
Old Mar 16, 2007 | 08:31 AM
insane04's Avatar
how about a complete truck in knoxville tn running with a 3.0 5spd so you will have everything you need and can rob it as you go? PM me if you think you may be interested
thanks jon
Old Mar 20, 2007 | 12:37 AM
danimalstwiztid's Avatar
I can help
In about a week or so I'll have a truck I'm gonna be getting for the engine. It has a 5 speed in it. I need a auto tranny though cuz mine is a bit mangled. If you interested get a hold of me.
Old Mar 20, 2007 | 02:54 AM
tweedersi's Avatar
pm'd you
Old Mar 23, 2007 | 07:15 AM
Rusty Davis's Avatar
On your automatic the bellhousing is part of the tranny (just like the transfer case), but on the 5spd its not. Now would be a great time to swap out that chain driven transfer case for a gear driven one as well :evilgrin:
Question- wouldn't the harness be needed for the reverse light if mandatory? You may also want to consider getting the parts needed for the beloved "clutch start cancel" switch.
Also, what climate control piece do you need? A cable for one of the sliders? A blower motor? If you're not sure you may want to wait till you have everything torn apart for the swap to see what you need
HTH,
~R
Old Mar 25, 2007 | 05:26 AM
I found the wiring harness and I think most of the engine bay wires are there.
You can splice the wires for backup lights take all of 15 minutes.
If you wnat the clutch cancel switch you can wire that in also or swap out the harness...but who the hell wants to gut the dash just for that switch?
The truck will start without the clutch being depressed...you just have to make sure its out of gear. .
I believe I still have the flywheel. I thru the clutch away. If your doing this swap you'd be stupid not to get a new clutch kit. Personally I'd get a new heavier flywheel also.
I'll give you a call later to discuss all this.
Old Mar 26, 2007 | 03:04 AM
tweedersi's Avatar
cool, i really need that harness and climate control, i never leave my truck in gear, you the clutch cancel swith its that big of a deal but if i swap out the harness i good right? i will call you later tonight. thanks
Old Mar 26, 2007 | 03:09 AM
tweedersi's Avatar
HTH,
~R
thanks for telling me about the bellhousing, on the climate control the hot/cold silder is bent to hell and the blue cable to the heat valve is also bent to hell, but valve is open, but i think my heater core in clogged. because i get no heat from my dash, but the heater core in the armrest is working just fine.
lucas
Old Apr 2, 2007 | 02:59 AM
tweedersi's Avatar
found everything but tranny and tranfer case
what is the tranny part codes i need?
Old Apr 2, 2007 | 02:04 PM
braverex's Avatar
Driveshaft
You will also need a slightly longer rear driveshaft... I did the swap last year and love having the manual instead of the slush box.
Old Apr 3, 2007 | 03:28 AM
dogdenii's Avatar
I have everything that you need from an 89, 3.0, 5spd 4Runner.
I'm in Lancaster, PA 17555.
email me: kamannsj@gmail.com
Old Apr 28, 2007 | 09:58 AM
ads86runner's Avatar
interested
If you dont get a reply i may be interested in 5spd!! Let me know. Thanks
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
wilbertd
Jul 6, 2015 07:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
