Wanted: Wiring harness for 1990 Toyota Pickup 22re 4x4
Old Sep 7, 2007 | 04:36 PM
vietsol's Avatar
I'm looking for a wiring harness for my truck. It's wiring is all cut up and it barely runs. Half the wiring isn't even connected. It was all chopped and they tried to re-do it til it ran. So if anyone has a wiring harness that's compatible with the 1990 22re 4x4 truck, that'd help a lot!! Thanks.
Old Sep 8, 2007 | 04:13 AM
onefast66nova's Avatar
I have one for an 85 SR5 with a 22re. Not sure if they are the same though.... Bill
Old Sep 8, 2007 | 04:33 AM
knucklehead38401's Avatar
Is it a auto or manual? Do you need the engine wiring?
Old Sep 8, 2007 | 11:35 PM
vietsol's Avatar
It's a 5spd manual. I think it has to be 89-92 to be compatible. Though I could be wrong.
Old Sep 9, 2007 | 11:17 PM
vietsol's Avatar
Yeah, it's the engine wiring. Got one laying around by chance? ^_^
Old Sep 10, 2007 | 08:07 AM
Well I have a 85 22re 5-speed if you find out it will work. Bill
Old Sep 10, 2007 | 09:01 AM
vietsol's Avatar
85 will require the entire chassis wiring
Old Sep 10, 2007 | 05:43 PM
I'm going to look through some boxes tomorrow and I'll let you know.
Old Sep 10, 2007 | 06:00 PM
vietsol's Avatar
awesome. Keep me posted. ^_^
Old Sep 11, 2007 | 07:41 AM
Look at your ECU and tell me how many pins are located on it. It should tell you on top how many it has.
Old Sep 11, 2007 | 08:05 AM
I've got 2 one has a 26 and 16 pin connector, and the other has 10,18, and 14 pin connector.
Old Sep 11, 2007 | 12:12 PM
ToyotaGuru's Avatar
Wiring Harness
Pre 89's are not going to plug into your fuel injectors or TPS for staters.
I think you have to find 89-92. IIRC our Friends at Toyota change the harness again for 92-95 with diffenet igniter and dist connectors as well.
Old Sep 11, 2007 | 01:59 PM
vietsol's Avatar
it's 10 18 14
hoping to find one that mated to the ecu with part number 89661-35150
Thanks for the info. This will help in my quest greatly so that I don't have to rewire stuff. ^_^
Old Sep 11, 2007 | 06:28 PM
Ok, I have one but it's a auto harness which will work, all you will have to do is jump a wire on the harness itself for the starter, which I can do for you.
Old Sep 12, 2007 | 08:54 AM
vietsol's Avatar
How much do you want for it? Would the reverse lights still work too? I've seen problems with reverse lights when using auto harness on manual vehicles. Let me know.
Old Sep 12, 2007 | 09:39 AM
dlbrunner's Avatar
I have a complete one from an 89, 4x4, 5spd. Plus computer
Make me an offer
Old Sep 12, 2007 | 04:28 PM
vietsol's Avatar
Make me an offer
Do you have ECU too? part number 89661-35150
PM'd
Old Sep 14, 2007 | 04:17 AM
I dont think the reverse lights would work.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
GorgeRunner
Jun 27, 2015 07:01 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
bprice0077
Jun 25, 2015 07:36 AM
TheManOutside
Jun 18, 2015 03:32 PM
